Bicycle Camera Mount for Under $1
Intro: Bicycle Camera Mount for Under $1
Mount almost any camera that accepts a screw in tripod for under a buck, using stuff you may already even have.
STEP 1: What You'll Need
What you'll need to make it:
1 x Reflector Mount (a friendly bike shop will give these away for free)
1 x Shim for reflector mount (also probably free at your LBS)
1 x 2 inch 1/4" x 20 thread count screw of your choice (pretty standard for most cameras)
2 x 1/4" wing nuts
2 x 1/4" washers
2 x 1/4" rubber washers
You might also need a drill with a 1/4" drill bit
2 x 1/4" wing nuts
2 x 1/4" washers
STEP 2: Drill Out Hole
The mount I had has 2 holes in it, make sure to drill out the farther one large enough for the screw.
You can use a mount that has only one hole, you'll just have the mounting screw double as the screw for the camera. Make sure you take into account that you'll need a 1/4" diameter hole through there when rummaging through their reflector bin.
STEP 3: Assembly
Put the 1/4" screw through the bottom of the mount, put these things onto it in this order:
metal washer
rubber washer
wing nut (could also use a regular nut)
wing nut (upside down! this one is more helpful if it's a wing nut)
metal washer
rubber washer
the rubber washers were to help absorb shock. it's not perfect, but it does a better job than nothing. still looking for an improvement on that though.
metal washer
rubber washer
metal washer
rubber washer
STEP 4: Put It on Your Bike!
I've got mine mounted on my handlebars for a front view. for a rear view you could mount it on your top tube under your saddle, most tripod mounts are offset, so depending on your model you might have a seatpost in the way. I'm using a Canon SD600 and it works just fine there.
29 Comments
A_Str8 16 years ago
BikerBill74 12 years ago
povertyonwheels 15 years ago
scottredd 15 years ago
sbhatla 12 years ago
bwoodward1 12 years ago
f3rg 14 years ago
The video is somewhat acceptable on smooth roads, but I wouldn't want to go anywhere near a trial. It's not the fault of the mount so much as the weight of the camera. The L20 is a pretty compact model, but it still weighs too much to hold steady, and I bet other similarly sized cameras will have the same issue.
jar0n 12 years ago
https://www.instructables.com/id/Updated-Bicycle-mounted-steadicam/
rocky502 13 years ago
razorE500s 13 years ago
ryanstan 14 years ago
macguy787 14 years ago
sharlston 14 years ago
dre0101 15 years ago
Graham9470 15 years ago
Yates_94 15 years ago
