Bicycle Frame Lamp
Intro: Bicycle Frame Lamp
So...I got my hands on a broken KTM carbon fiber bicycle frame, and decided not to throw it away, and do a cool looking lamp.
The frame got crushed by a truck in a warehouse, it was pretty damaged in the rear, but the front was new.
Lets start the project, go to the first step :D
STEP 1: Cuting the Frame
The frame had a long crack in the top tube, so i cut it where the crack ended.
I used a circular saw at work.
STEP 2: Base Part 1
I cut 2 acrylics with 37cm by 14cm from a 10mm black matte acrylic sheet.
STEP 3: Base Part 2
I wanted to be able to turn the lamp.
So i decided to glue 3 acrylic hinges in the base.
I glued 2 small acrylic spacers with magnets to stay in place.
STEP 4: The Trouble Light
The lamp itself was made with a modified orange trouble light.
I have made some cuts on the light handle, to be able to fit it in the frame.
The trouble light fitted snugly in the frame.
So I didn't had to hold it with nothing, like screws or glue.
STEP 5: Head Tube Cover
I needed too cover the head tube on the top.
So i had to cut a plastic circle to fit in the tube.
And then, i drilled a hole in the center, to pass the cord to the trouble light.
STEP 6: Cable Management
In the first photo, you see the cable passing thru the original brake cable hole.
I only had to enlarge the hole, to fit the cable without damaging it.
STEP 7: Base Part 3
In this step I finished the base.
I drilled a hole to pass the cord again.
I screwed 2 closet rod flanges to the base, then screwed the frame to the flanges with self-drilling screws.
The frame becomes attached to the base.
STEP 8: Final Touches
For a final touch, I used again an original brake cable hole to pass a piece of cord, along the bottom tube to another hole that I had drilled.
I fixed the cord with zip ties to the original frame spares.
This cord it's just for aesthetics purpose.
In the main cord i atached a black power plug and a switch
Sorry, I dont have photos for this
STEP 9: Final Result
It was a great journey, from a smashed frame, to a awesome lamp, to place on my bed room. ;D
Hope you like it.
Something you need to know leave a comment. :D
15 Comments
ehmbee 8 years ago
Very cool, and there's a lot of other ways you could go with this, like adding a shade as previously mentioned. Something from IKEA adapted to your needs, or a pendant lamp shade from a big box home improvement store would work, also stainless or glass bowls from the thrift or dollar stores. Great work!
JPBlind 8 years ago
Raitis 8 years ago
JPBlind 8 years ago
Just4Fun Media 8 years ago
Have a great day! :-)
JPBlind 8 years ago
Good idea xD
Nice day too you too sir :D
BONGO350 8 years ago
Great
BrettHacks 8 years ago
What a cool use for a busted frame! Thanks. Voted.
JPBlind 8 years ago
Ty..wee need to recycle :D
diamondemb 8 years ago
Very creative.
JPBlind 8 years ago
Thanks.
amberrayh 8 years ago
Great idea! This would make a nice gift for a bicycle enthusiast. You should enter this in the Bedroom Contest!
JPBlind 8 years ago
Thanks glad you like it.
I saw the contest and i already entered :D
Erelu 8 years ago
If it was done using a metal frame, you could take it all kinds of design directions - BUT remember to use a grommet or other cable protection, especially if you drill your own holes.
inspiring
JPBlind 8 years ago
I think you are right, but in this case, it wasn't necessary..because the frame is made of carbon fiber.
Glad you like it TY.
