Bicycle Wall Mount From Pallet Wood
Intro: Bicycle Wall Mount From Pallet Wood
So my Bicycle was always in the way and so I fix it.
Was a Project that i did you the fly no planing aside, well plans who need thems :P
Let you imagination go and do it !!!!!
For more wierd projects check my youtube channel
STEP 1: What You Need
* Pallet wood
*screws
*wood glue
*washers
*threaded rod
*lock nuts
STEP 2: Cut Wood and Glue the Boards
Cut the Wood to a size that you can glue together
STEP 3: Glue Them Together
You can use this tip tho glue them
STEP 4: The Side to Hold the Rod
Cut a shape to hold the rod and with enough space to the iron move
STEP 5: Make 2 Equal Holders
I used a router to make 2 pieces alike
STEP 6: Scrap Iron
Make sure you use something that strong enough to hold the bike. I used a scrap Ironbar
STEP 7: Strength for the ROD RWaaarrrr
cut some wood bolcks to use as spaces and add strengh to the threaded rod
STEP 8:
Glue , pre dril and add some screws to the sides
STEP 9: Drill the Holes
Put some holes as you like to attach it to the walla
STEP 10: Lock Nuts
Put the lock nuts on the threaded rod
STEP 11: Back Tire Wood Support
Use a scrap piece where you can you the back tire and thats it
STEP 12: Attach to the Wall and DONE
Last part is put it where you want it :D and put the bike in and there you home made bike wall mount
4 Comments
DIY Hacks and How Tos 7 years ago
Nice. I need something like this in my garage to save some floor space.
TrashWoodshop 7 years ago
that was exacly my tought
teaMJPx 7 years ago
thanks for sharing.
Thats a good idea but the threaded rod should be thicker for sure
