Diy Mini Scrunchies (No Sew!)
Introduction: Diy Mini Scrunchies (No Sew!)
About: Hi! I'm Sweet Strawberry, and I love baking and crafting! In my instructables, I have designed recipes or projects made for beginners or simply anyone, they're that easy :)
Do you have those annoying mini elastics that tug on your hair and pull it out? Did you know that scrunchies reduce hair loss and are more comfortable to wear? Today, I'm gonna show you how to make mini scrunchies and big scrunchies, depending on what type of hairstyle you want to do. Let's get started!
Supplies (Mini scrunchie)
- 4x16 cm piece of fabric
- Hot glue gun
- Elastic (Make sure it is the thin type of elastic so it can fit in your scrunchie. You can reuse elastic that comes with disposable face masks, or broken hair ties can work as well)
- Mini safety pin
Supplies (Large scrunchie)
- 8x35 cm fabric piece
- Hot glue gun
- Elastic
- Safety pin
Step 1: Mini Scrunchies
1. You are going to add hot glue to one of the long edges of the fabric, and fold the other side on top of it so it looks like the image above.
2. Then, you are going to pin a safety pin to your elastic (make sure it is thin enough to fit in the tube), and slowly thread it through the tube, making sure to leave elastic on the end of which you started in. (You can pin one side of the elastic to the beginning of the scrunchie to keep it in place).
3. Then, you are going to pull the elastic from both sides and tie a knot. Cut off the excess, and tuck it into the scrunchie tube. Then, close the leftover gap with hot glue. You're done! Enjoy your fashionable and comfy scrunchie!
Step 2: Large Scrunchies
2. Then, you are going to pin a safety pin to your elastic, and slowly thread it through the tube, making sure to leave hair on the end of which you started in. (You can pin one side of the elastic to the beginning of the scrunchie to keep it in place).
Big vs Small Challenge
Be the First to Share
    • Box Challenge
      Box Challenge
    • Explore Science Challenge
