Introduction: Bike Badge Belt Buckle
If you have a motorcycle from a non-mainstream manufacturer, it can be difficult to get promotional wear. With this Instructable I intend to help redress this in some small way, by using a tank badge to create a belt buckle.
This one buy the way states IMZ in cyrillic , the manufacturer of Ural motorcycles in the old Soviet union.
Step 1: Parts
1x Bike tank badge (metal is best)
1x P clip
1x D ring
1x m4-10mm brass screw
1x m4-15mm brass screw
2x m4 brass washers
1x m4 brass nut
1x m4 brass dome nut
Step 2: Belt Attachment Assembly
Pass the D ring through the P clip.
Step 3: Buckle Assembley
Place the 10mm screw through the hole on the left side off the badge, add the p clip washer and dome nut. Rotate the p ring and tighten dome nut.
Step 4: Belt Tang Assembly
Pass the 15mm screw through the remaining hole, add washer and nut, and tighten.
Step 5: Finished Buckle
Just attach to your belt, and wear with pride!
Trash to Treasure Challenge
