Bike Lock Holder
Intro: Bike Lock Holder
Hear is a neat and easy way to make a bike lock holder that stays on your bike.
more specifically this is for the U-Bolt type bike locks.
the cable ones, you can usually just wrap around the seatpost,
but the U-bolt are a little more difficult to carry around while your biking.
this can be built for around $3.50 (less if you already have some of the parts) and take about 10 minutes.
STEP 1: Materials and Tools
You will need
-one foot section of PVC (for my lock i used 1 1/4" pipe, but it may ne different for your lock)
-2 hose clamps
tools:
-saw
-sharpie
-3/4" drill bit
-drill
-clamp (not required, but helpful)
-2 hose clamps
tools:
-saw
-sharpie
-3/4" drill bit
-drill
STEP 2: Marking Your PVC
hold your PVC pipe under your lock and mark how long it is with your sharpie.
i marked both ends to be cut, since they didn't cut it straight at the hardware store.
STEP 3: Cut Your PVC
Next you will cut the PVC.
if is very helpful to hay a vice, or a clamp.
you also want to use a saw that has relitively small teeth.
i prefer a hand saw over an electric because it allows me to work slower and make less mistakes.
STEP 4: Mark the PVC for Holes
Next, hold your PVC under your lock again,
and mark where the holes in the lock are.
for this, you'll have to have the lock open.
you could simply make the pvc short enough for the lock to go through,
and then you wouldn't even need holes.
however i opted to drill holes so that the lock wouldn't swing back and forth.
STEP 5: Drilling Holes in Your PVC
Next, drill the two 3/4" holes in the pvc.
STEP 6: Check to Make Sure Your Lock Fits
Before putting the lock on the bike, make sure it fts in the PVC.
STEP 7: Attaching the Holder to the Bike
Next use your two hose clamps to attache the holder tot he bike.
i wrapped elecrical tape around my tube, so i wouldn't scratch the paint.
to use, simply unlock the lock and use it.
24 Comments
TreeT2 6 years ago
Thanks for the write up! Here's my little rendition. Local hardware store did not stock a pipe less than 10ft...Hoping the cable ties will hold up. Gear tie at the bottom to prevent lateral movement.
Cheers!
KevinA216 6 years ago
This is an excellent design idea! I've got an oversized U-lock and a thicker frame, none of the mounts on the market work.
rjmeyer67 6 years ago
killerjackalope 16 years ago
lidaye 8 years ago
Kactapuss 15 years ago
tmiron 16 years ago
so, you see locks just help keep the honest people honest
stncilr 15 years ago
ChrisCanMake 17 years ago
Just a note for those thinking of making this ulock holder:
IT ONLY works for locks with the keys that fit into the END of the lock "bar" (the part where the lock mechanism is.)
With both my newer cyclinder key and flat key locks, the key enters the lock perpendicluar to the "lock bar".. so this design won't work (as the key would have to morph through the PVC tube AND would end up in the bikes crossbar!) SEE ATTCHED PICTURE
HOWEVER, i'm working on a mod for this design (since its pretty slick) to accomidate this type of lock. i'll put it up soon =)
jaime9999 15 years ago
lidaye 8 years ago
bo88y 13 years ago
~~ Instead of drilling holes in the pipe for the shackle to pass through, make slots that extend 1/4 of the way around the circumference of the pipe, so that the lock can swing 90 degrees to one side when it's in place. Drill another hole through the pipe at the location where the keyhole will be when the lock is swung up to the side. Putting the lock in, and taking it out of this holder takes place in the swung-up position, and gravity will hold it down for the ride.
~~ Given the geometry of the pipe and the crossbar and the key, you probably wouldn't need the full 90 degrees of swing to get access to the keyhole. No sense cutting more than necessary, so make the slots for an 85 or 80 degree swing, and cut the keyhole-hole in the appropriate spot. Each slot is made by drilling a hole at either end and sawing out the space in between with a keyhole saw, first by laying the pipe down and cutting in the usual manner for cutting pipe, and then by slipping the saw into the slit and cutting the rest with short strokes, to avoid cutting past the holes.
~~ If you're worried about the thing flapping around, and are lucky enough to have a bike with a crossbar that inclines upwards at the front, make the slots "L" shaped, by drilling another hole behind the bottom ends of the slots, and connect them by sawing, so that the lock will naturally slide backwards into the place where it can't swing. You could mount this version on the seatpost, too.
Skyfinity 14 years ago
Waddib 15 years ago
chephy 16 years ago
Almax9633 16 years ago
http://www.youtube.com/watch?v=6Ip5QoMFyi0
http://www.youtube.com/watch?v=5WeEq_SxNRc&mode=related&search=
theRIAA 17 years ago
http://www.youtube.com/watch?v=G1yImVLW_Q0
We only used, silent forms of attack on the ITV show, Bolt croppers and wire cutters. We did not have the miniature bottle jacks at the time of testing, however I have now and they are very very effective at attacking U locks.
If you want to avoid a minuature jack being used on a U lock, make sure you don't leave enough room for a tennis ball. Other wise the miniature jack fits in between both sides of the shackle at the body end, then proceeds to split the body in two.
It makes less noise than opening a crisp packet!
A
Maybe alan is right and the scrotes only steal cycles with non approved locks, or maybe they don't care. Maybe they know, like we have found in the last couple of weeks that most of the stuff approved is little more than a minor inconvenience.
Wake up Alan, scrotes use bolt croppers, wire cutters and miniature bottle jacks. I do feel for you chaps, the selection of approved stuff we tested for ITV was utter crap.
Change however is coming, Sold Secure and Thatcham are going to struggle to wiggle out of this one.
