Introduction: Bike Trailer
Simple bike trailer.
Made from a baby pushchair, bike tube and broom stick.
Only 3 main parts needed and min tools needed to build it
Speed does not matter for the trailer as it has good build in shocks and tires are not super hard.
It follows the bike rather well also so its easy to pull. Feels very light
Step 1: Items Needed
Some things are needed at first.
a. Try find an old baby push chair.
b. Broom stick or some sort of light strong wood pole
c. Old bike tube
Time taken to build up was about 40min.
Easy to make.
Cost : 0 depending on what parts u can find.
Step 2: Steps
Chop up the baby chair as needed.
Cut off parts u dont like but keep the structure strong. Modify as needed. I cut off the top and some other bars. This will all depend on what u find.
Step 3: Hook Up to the Bike
Then get a good length for the broom stick. Check lenght before u cut it. Make notches in the wood to make it not slide away from the chair's body. I looked where i would tie it to the buggie and then there i made slots so that it hooks to the buggy before i started to tie it on.
Then cut up old tire tube into strips. Tie as best u can. U can use any knot u like as this stuff is very strong and if u pull it tight while u do it it will NOT move.
Keep a long section to slide over end. Slide over about 30cm and then use the rest to tie to the seat. If u carry heavy things make sure all the weight is over the axle this will minimize the stress on the connecting arm.
Easy! Let me know if u guys build one
12 Discussions
12 years ago on Introduction
what kind of bike is that?
23" Frame Mountain bike . GIANT 26" wheels
the type with two wheels...
11 years ago on Introduction
I may have got the good idea from you after seeing the trailer you made. I picked up a pram and a German guy who stayed with us sold me his bicycle when he returned to Germany...well, the hook handles on the pram arms slipped perfectly into some galvanized tubes I had. I drilled hole for bolts and used loctite nuts and the hooked handle fitted perfectly beneath the removable bicycle seat...yay. I can remove the removable bicycle seat and hook er up! Now I am going to offer services for cleaning computers and now I can pickup and deliver as a service as well...yay. ***Thanks a lot ***
Reply 11 years ago on Introduction
Great glad to help . u got pics of what u made ?
11 years ago on Step 2
i don't follow what you did here with the end of the broom, attaching it to the bike post. is this the inner tube from a bike? did you just slip it over the end of the broom handle and then tie around the bike post? is it just luck that the broom diameter matched up with the innertube such that it doesn't slip out? if so...that's freakin genius. you didn't have to use any glue or anything to keep it from slipping out?
11 years ago on Step 3
What is are the relative merits of attaching to the seat vs. to the back wheel? Can you untie the seat/broom stick connection easily, or is it pretty much on there for good? Thanks. Nina
Reply 11 years ago on Step 3
The tube is so strong but flexible also. U can take it off very fast less than 10 sec. After 1 or 2 years the tube might get weak if its in the sun. To untie u need to know how u did it so other people will not be able to steal it easy because it looks very tight but u can get it off easy.
Sure sounds easier than some of the other forms of hitches. Luckily, I just blew a tire, so I just happen to have the inner tube ready for recycling. Thanks.
Nice
13 years ago on Introduction
real cool trailer. i'll ask my parents if they have my old stroller!!8)
Nice way to end goal. alot shorter than mine...hope the image works..
