Bike Light Generator
Intro: Bike Light Generator
This project came about because batteries go flat. Especially when you don't want them to.
If you want a bright light on the front of your bike and don't want the hassle of recharging batteries or heaven forbid having to buy new ones, then check this out.
Some expense is required, but no more than the cost of a decent halogen head light.
Also there is some manufacturing involved, but if your still keen, this system works.
The specs are
-No Batteries!! Energy Storage is two supercapacitors 100F, 2.7volt in series, giving 50F at 5.4volts.
-It takes a few minutes to charge but the light will work at full brightness as soon as you start pedaling.
-It has a 15min run time before it starts to dim (when you stop at the lights and the generator is not running) .
The 1Watt LED requires 3.5volts, using the right resistors this time can vary between 4 to 30 mins.
The LED can draw up to 350mA, but my setup drew 160mA, still bright enough to dazzle drivers.
-The generator can run the light and maintain the charge. I used a Stepper Motor from an old dotmatrix printer, it can generate 500mA when shorted on a multimeter.
-Another advantage is the capacitors have no memory problems and are self regulating (meaning they cannot be over charged).
The specs are
STEP 1: Parts Required
First you need to source a decent Stepper Motor. You need one with a very low resistance in the coils, this should give you the Amps required.
Mine had 2.88volts and 2.4A on the label, the resistance was 1.2ohms across the coils. On testing this Stepper motor put out 500mA when shorted with the multimeter at 400rpm!!.
At 15km/h the average bike wheel will be doing around 160 to 200 rpm. That means the motor could be mounted near the hub of the wheel reducing the effort to drive it, unlike the old dynamo running on the tyre at a 1000rpm.
Secondly, you need to purchase a couple supercapacitors which could be found here
http://www.altronics.com.au/index.asp?area=item&id=R4945
Thirdly, you'll need
-x8 1N4004 diodes,
these will rectify the AC generated by the stepper motor to a DC supply.
-x1 LM317T Voltage Regulator,
http://www.reuk.co.uk/Using-The-LM317T-To-Regulate-Voltage.htm
-x1 0.1uf ceramic capacitor (suggested by LM317 datasheet)
-x2 Resistors for the LM317T, a 240 ohm and a 820ohm 1/4watt will give you the 5.5 volts needed for the capacitors, this should not be exceeded!!
-x1 LED 1 Watt
http://www.jaycar.co.nz/productView.asp?ID=ZD0424&CATID=33&form=CAT&SUBCATID=917
-x1 Resistor for the LED, 11ohms 1/2watt, this creates a current draw of about 160mA.
Other items to find are
a torch/headlight case to fit the LED into.
a small case to protect the capacitors from damage.
Some wires.
A 100mm dia. plastic drain pipe approximately 25mm wide, epoxied to the spokes of the wheel.
A pulley or rubber wheel for the stepper (approx 50mm dia) and
tools, soldering iron, and what ever is required to fit it to your bike.
-x8 1N4004 diodes,
-x1 LED 1 Watt
Some wires.
STEP 2: Building the Generator Circuit
Firstly I didn't use a circuit board, I just soldered the components together and then covered with an epoxy glue to protect it.
My Stepper Motor had 6 wires, 2 are Com which you don't use, and the other 4 come from the coils.
Solder the diodes together like the diagram, this creates a parallel circuit giving you a DC supply.
Solder the Capacitor between the + and -, this stabilises the Voltage Regulator.
Then solder the LM317T and the resistors in place.
Fit the LED into an old headlamp with the current limiting resistor.
Run the wires from the light to the Capacitors via a switch, and then down to the voltage regulator.
Stepper Motor==Voltage Regulator==Capacitors==Switch==LED
A slight modification I did was to add a resistor in series to the Capacitors to limit the charging capacity. The reason being if the capacitors are flat they will pull the voltage to low for the LED to operate. The down side is the Capacitors will take longer to charge but the LED will work straight away.
To Be Finished with more photos to come.
STEP 3: Fitting Stepper Motor to Bike
Finally got around to fitting the stepper motor to the bike.
I used Metal Pipe clamps to hold the motor and used the mounting holes normaly used for the disk brakes.
Used an old bike tube as a tensioner, ( not shown in photo)
The Motor wheel is running on a section of 100mm dia PVC pipe, This was fixed with glue and tape, but might need screwed clamps as the Bike tubes tension needed to be good to stop wheel from slipping.
22 Comments
bryce5 5 years ago
Kolyanovech 7 years ago
I have sourced a stepper motor but the calculated resistance is roughly 68 ohms with load. I'm very new to this thing, but my guess is that the resistance is way to high, correct?
Here's the specs for the motor: http://www.nmbtc.com/motors/part-numbers/Brush-DC-12V/MXN13FB12F/4593
gordoflash 7 years ago
I believe the motor you have is not a stepper motor, stepper motors have 4,5 or 6 wires, not 2. The DC motor will produce power, but not enough. The stepper motor I used will generate about 1 amp I think.
Ah, drats. I had hooked it up to a cheap dollar store circuit board with two LEDs. I spinned the axel with my finger and got near-full light. The motor was from a stereo system I took apart...I'm not sure what it was used for, but my guess is that it powered a mechanism that spun the interface open when the stereo was given power. I figured the bike would power more current than just my finger. I might try to experiment around with it until I find a more appropriate motor, but thanks for the confirmation!
minimeccanica 8 years ago
Nice instructable! One day or the other I want to put together a bicycle charger for my phone, requiring 0.5 to 1 Amp to charge in a decent time. Anyone knows how to guess, from the several stepper available, how to choose the one sufficient to provide a current in that range?
sam522 10 years ago
hello guys;
i have sun tracker project, i wanted anyone can help me to know the specifications of my supercapacitor ( my dcsource voltage is 20 volt and i want 1 amp current for my actuators)
thanks.
luxstar 11 years ago
Hello Locci
Where to get 2.7 volt super capacitors:
http://www.futureelectronics.com/en/Technologies/Product.aspx?ProductID=DB5U407M35060HASAMWHAELECTRICCOLTD8382301&IM=0
ã
This one is a 400 farad.
ã
Good lux with your project.
sumaru 13 years ago
gordoflash 13 years ago
tinstructable 13 years ago
I discovered the equation for 2 capacitors in series is,
Ct = C1 x C2 / C1 + C2
more than 2 capacitors, it should be
Ct =1 / ((1 / C1) + (1 / C2) + ...(1 / Cn))
taken from
http://www.tpub.com/neets/book2/3e.htm
Wisley 13 years ago
loccci 13 years ago
loccci 13 years ago
hobbyhawk32 14 years ago
How can I be sure that my motor will work for this?
gordoflash 14 years ago
4 wire motors have no Com wires, which can make it easy.
6 and 8 wire motors, you should still only end up with 4 Coil wires.
Use a muiltimeter to find the resistance (ohm) value between wires.
Coil to Com value should be approx. half the Coil to Coil value.
4, 6 or 8 wire motors can all be used, join all com wires together.
any problems, let me know.
thanks though, this really helps.
