Bike That Charges Your Cell Phone As You Ride!
Intro: Bike That Charges Your Cell Phone As You Ride!
My friend Jack and I wanted to make a bike that charges his cell phone as he rides, so we decided to use a small DC motor to power it!
For the peeps who don't know why it saves energy: 1st, you charge your phone without electricity from a power plant, obviously, because you are creating electricity by riding. 2nd, it gives you a reason to ride to wherever you want to go, reducing your carbon footprint drastically.
Note: the video is on the last step
STEP 1: Get Your Parts!
OK, so the parts list is pretty basic.
1 Bike that you are willing to do some stuff to (every thing is reversible)
1 Small gear that will fit into your chain
1 Small piece of wood
1 Smallish DC motor
1 Cell phone
1 Cell phone charger that you are willing to destroy
1 Solder
A crap load of duct tape
Hot glue
Assorted washers, nuts, and bolts
Tools:
Soldering Iron
Socket wrench
Hot glue gun
Coke and Dr. Pepper
Good music to listen to
A friend to help you out
1 Smallish DC motor
1 Cell phone
1 Solder
Hot glue
Tools:
Soldering Iron
Socket wrench
Hot glue gun
Coke and Dr. Pepper
STEP 2: Mounting the Gear Onto the Motor
OK, now you need to mount your gear onto the motor. Our axle was little too small to fit into the gear, so we wrapped it in some duct tape. We then used a copious amount of hot glue and some washers to hold it in place.
STEP 3: Mounting the Gear and Motor Onto the Bike
Gee, we sure are doing a lot of mounting today! OK, this part is easy, you just need to put the motor setup on the bike in a way that the chain will catch on the gear and spin the motor. Its easy to do this with some hot glue, zip ties, and duct tape.
STEP 4: The Wires!
OK, now for the electronics, just cut the head off of your charger and strip the wires off of it, and then solder them to the motor. You may have to use some resistors depending on the voltage that your cell phone takes. You can also wrap the finished product in some colored tape to match the bike like we did!
STEP 5: Connect the Cell Phone and Ride Off Into the Sunset!
OK! You are done! Just put your chain on the gear and ride off into the sunset! Thanks for reading!
53 Comments
toutafarelabcefg 3 years ago
stuffdone 8 years ago
You can just get a $15 bike generator complete with head and tail lights. Simple voltage regulator if you like.
ukeboyska 8 years ago
Alternatively, a decent, cheap product that does this (and way more) is finally on the market: http://sivacycle.com/products/the-atom
SkyKing101010 9 years ago
This is a great idea. If I could still ride a bike I'd be thinking about a way to modify it to charge a 12V motorcycle battery so I could run a CB radio or something from it.
The derailleur sprocket works beautifully. My main concern is the stability of mounting it using hot glue and duct tape. Wouldn't it eventually jiggle out of position because of bumps and changing gears and so on?
Also, the dynamo is a great idea (we used them for bicycle lights when we were kids), and it gives enough voltage to charge a phone no problem, but I'd use a bridgerectifier to change it to pulsating DC, and a proper capacitor filter it out to smooth DC. I'm pretty sure you wouldn't need to regulate the voltage, but I don't know what to do with the extra amperage so charger doesn't burn out the battery. Hmmmmm
CanadianGamers 10 years ago
How many volts does it have to be 12?
azhar12 10 years ago
Nharzhool 10 years ago
When I get myself a bicycle, will go through all of this.
Also thinking of slapping the rectifier in there with a regulator and rechargeable batteries. Thanks TheWelfareWarrior and flaresam for all of this.
tmoupo 11 years ago
imakethings 15 years ago
alexsolex 15 years ago
flaresam 15 years ago
Penru 13 years ago
Here's what i have in mind, add a battery system (something like a Powerizer 12v 4200 mAh NiMH Battery for RC Car Boat should work and fit under seat). this battery would be used to run headlights, tail lights/turn signals and also power my droid phone (running a dash board app to give me speedometer, odometer, compass and gps. This would be accompanied by a 80cc slant head engine. Well that is my idea... Any help would be great!
Thanks
Penru
rimar2000 15 years ago
Kiteman 15 years ago
jesusfreek 14 years ago
hotrodbuild 15 years ago
Wasagi 13 years ago
