Binder Clip Phone Car Mount
Intro: Binder Clip Phone Car Mount
Yo, this instructable features one of the most undeniably, infinitely useful office objects ever made: The Binder Clip. You can find them almost anywhere, and their uses, both intended and repurposed, are limitless. In this little 'ible, I'll show you how I made a phone mount for pretty darn cheap (college and having money don't usually go together). Read on!
Materials:
1 Large binder clip
1-2 Rubber bands or hair ties
2 lengths 6 inches long of Paracord, color your choice
Notes on materials:
Binder Clip - size it to your phone, the handles should have to open a bit to fit the phone in
Rubber bands / hair ties - I used black hair ties (...no, not a girl, just have a sister) because i thought it looked more pro
Alright, grab your materials and lets start.
Materials:
1 Large binder clip
Notes on materials:
STEP 1: Finger Prep
In this step, we prepare the fingers that will hold the phone. I am referring, of course, to the silvery parts of the binder clip.
Even though this is one of the more crucial steps, it is very easy. Just take the two metal 'handles' off of the binder clip. Put them in a vice and clamp the rounded end up to where it bends. Tap with a mallet of hammer until you have about 20 degrees of bend in the part. Repeat for both fingers.
Voila!
Voila!
STEP 2: Cover the Fingers
Next we prepare the protective sheath for the fingers. Nobody wants a scratched up phone! For each of the lengths of paracord do this:
- Gut it: remove the inner strands of the paracord to make room for fingers
- Fuse or Seal it: Stop the fraying of the sheath by fusing the edge, you don't want to shut it of, just melt the edges. another option is fray check, but I thought it was easiest to insert the hot end of a soldering iron into the end for a quick second, then going around the edges and melting them
- Fish the finger through the sheath like pictured: try and get the sides even, at least for aesthetic's sake ;)
- Reattach fingers to binder clip
STEP 3: Install Reverse Tensioning System
That's fancy speak for put rubber bands on it. You may find that you have to take up some slack; in that case, simply put another loop over the finger, or find a smaller rubber band. When properly tensioned, the device should have a light tension with fingers resting on the sides of the binder clip, and should hold your phone snugly.
STEP 4: Enjoy
One of the beauties of this mount is its easily reconfigured nature. If its not holding onto your phone, make the tension a little snugger. If you don't like where it is, find a different place. If you don't like people breaking into your car because they see a mount, take the mount down when you leave the car. If you don't like people breaking into your car because they see the ring that a typical GPS suction mount leaves, well...you don't have to worry about that with this mount! Hurray.
Placement: The phone goes between the metal fingers, you can rotate your clip for landscape or portrait orientation.
FYI: Mine is certainly battle-tested, as I have been on multiple GPS intensive trips (like 20 house calls in a different city...that was fun). I attach mine to the console air vent; no over-heating issues on my phone ;)
PS: Also, my girlfriend thought it was funny that I started with yo...so she made a rap:
Yo this is my instructable, its so cool and doable, make a neat phone clip, your street cred surely wont dip, youll need paper clip and vice, if you miss you might need ice, dont forget the paracord and hair ties, scratching your phone wouldnt be wise
49 Comments
80$man 12 years ago
repeet13 12 years ago
80$man 12 years ago
stephreust 3 years ago
MohammadV1 7 years ago
abrown435 8 years ago
I love this idea. I actually just used to top part of a selfe stick I found at the dollar store, unscrewed the handle from the top, and velcroed it to my dash. This isn't the same one I used but it would probbaly work the same: http://www.dollargeneral.com/product/index.jsp?productId=81757706
Mo0k 8 years ago
Great Instruct!
mkaercher 9 years ago
I love this phone clip. Very easy and adaptable. Thanks!
hholland419 9 years ago
Made it, like it a lot. Great for hands free in the car, charging port still available. Thanks!!
SarahT2 9 years ago
I found this post to be very informative and helpful. I will have to recommend you to my friends.I am very thankful to the you for giving this post.
http://winnergear.com/
eilu 9 years ago
I made one with a 2" binder and some silicone rubber hair ties. Don't have access to a hairdryer at the moment, but I'll be adding heat shrink tubing when I do. Also, since I don't have a vise, I had to use a pair of pliers (one long nose, one ordinary) and a LOT of effort.
jbman2 10 years ago
Heres my idea,
Affixing a paper-clip to a plastic iPhone case with a pop-rivet
Total cost $0 (Free iPhone case from a lighting and sound gear roadshow)
the metal arms slide into the gap between the console and trim
Tomahawk92 11 years ago
ghwhitcher 11 years ago
toiletbowl martini 11 years ago
repeet13 11 years ago
zachaquack1987 11 years ago
nedfunnell 11 years ago
damien381 12 years ago
girvster 12 years ago
It would be better if i could find a way to hold my phone both vertically and horizontally tho.
Any ideas?
