Introduction: Biogas at Home- Cheap and Easy
Hi there, I am Sahas chitlange, aging 14, from India. here is my homemade cheap and easy to build mini Biogas plant. It burns for approx. 20-30 mins on a bunsen burner. you can add anything from your kitchen waste ( Exept Onion peels and eggshells). In 12 hours the Gas is ready for use. It is very easy and cost effective to build (only 2-3 dollars) and gives many useful products.
the end products of this system are:
1) Methane : (Can be used as a fuel)
2) Slurry : (the spent slurry is exellent manure)
The main components oof this system are:
1) Inlet pipe
2) digester tank
3) gas holder tank
4) slurry outlet pipe
5) gas outlet pipe
Snapchat and Instagram: @chitlangesahas
I'd love to connect with you guys on Snapchat and Instagram, I document the experience, learning lessons and also answer questions on those platforms. Looking forward to connect! Here is my username for both: @chitlangesahas
Step 1: Chose the Correct Container
Step 2: Make Holes
Step 3: Fix the Inlet and Outlet Pipes
Step 4: Making the Gas Holder Tank
Step 5: Time to Mix the Cow Dung !
Step 6: Almost Finished!
Step 7: Working Photos
The photos of the system working are provided....... the heat is so much that it melts a thin sheet of tin in just 2 mins!!!! if you like this i'able please like and comment....
Step 8:
![Instructables Outdoor Projects Contest](https://content.instructables.com/FKJ/M4IM/HMUTIL2U/FKJM4IMHMUTIL2U.jpg?auto=webp&frame=1&width=320)
![Build My Lab Contest](https://content.instructables.com/FTE/3I4X/HJKC2IYE/FTE3I4XHJKC2IYE.jpg?auto=webp&frame=1&width=320)
![Home Remedies Contest](https://content.instructables.com/FH4/8Y1W/HLZRUWOM/FH48Y1WHLZRUWOM.jpg?auto=webp&frame=1&width=320)
![Hydroponics and Indoor Gardening Contest](https://content.instructables.com/FZN/QCKN/HN81YXWA/FZNQCKNHN81YXWA.jpg?auto=webp&frame=1&width=320)
