Bixler 2 Kit How-To Guide
Intro: Bixler 2 Kit How-To Guide
Overview:
The Bixler 2 from HobbyKing.com is one of the best kits for incoming r/c airplane hobbyist. This plane is great because it is a strong durable airframe that will grow with you. From first flight to fpv, this plane is ready to handle it all. The aspects that attracted me to this plane were the fact that I would be able to build my plane, large payload capability (GoPro, 3DR sensor package, etc.), carbon fiber reenforced wing and fuselage, side plates, and optional flaps. This Instructable will guide you from start to finish of the HobbyKing Bixler 2 (Kit) with tips that I have learned.
Purchasing:
Purchasing:
I suggest to buy the ARF (Almost Ready to Fly) version of this airplane. I bought the Kit version because I want to customize my Bixler 2 and I didn't want to pay for international shipping (+$25). The difference between the the ARF and the Kit version is the AVF version includes the brushless motor and servos. Here are the links fro both ARF and Kit versions:
Bixler 2 AVF Version:
http://www.hobbyking.com/hobbyking/store/__24474__Hobbyking_Bixler_2_EPO_1500mm_w_Brushless_Motor_Servos_and_Optional_Flaps_ARF_.html
Bixler 2 Kit Version:
Additional Purchases:
Kit Additional Purchases (Recommended):
- Radio(6+ Channel): Spektrum DX6i with receiver
- Battery Charger: Primal Radient Charger
- Servos(9 gram x 6): 4 x JR 9g servos
- Battery(Li-Po 11.1V 1800-2200 mah 15C): E-Flight 3S 11.1V 2100mAh
- Speed Controller(20A x 1): E-Flight 20-Amp ESC
- Motor (KV1300 x 1): Replacement Bixler 2 Motor
- Servo Extensions: JR heavy duty 24"
- Solder Equipment for my Charger and ESC connections
- 3M Outdoor 10lbs Mounting Tape
AVF Additional Purchases:
- Everything but Motor and Servos
STEP 1: Mount Motor
Mount Motor:
Screw the motor to the motor mount that comes in the kit. Add glue to the foam where the mount will be placed then place the mount in the designed slots. Warning : Make sure that the slot on the mount is faced down for proper thrust angle.
STEP 2: Attaching Rudder and Elevator Motors
Attaching Rudder and Elevator Motors:
First make sure the steel wire is placed into one of the holes on the arm of the servo. Then I cut a piece of 3M mounting tape and stuck it to the fuselage and servo. The reason I used mounting tape is so that I could remove the servos later for other projects. If you don't get mounting tape, simply glue the servo to the fuselage.
STEP 3: Glue Fuselage Together
Glue Fuselage Together :
Add glue to the edges of the fuselage and then place both pieces together.
STEP 4: Attaching Skid-plates
Attaching Skid-plates :
Cut out both font and back skid-plates from the plastic with scissors along the scored lines. Then, one at a time, glue the skid-plates to the fuselage in the proper positions.
STEP 5: Attach Fuselage Carbon Fiber
Attach Fuselage Carbon Fiber:
Add glue to the groove in the bottom rear of the fuselage. Then place the carbon fiber spar, back end slips in first, into the groove.
STEP 6: Attaching the Aileron and Flap Servos
Attaching the Aileron and Flap Servos:
Aileron:
Find the servo hole nearest to the tip of the wing and glue or tape (in my case) the servo to the wing. Run the servo wire in the groove that you find by removing the the pre-cut out foam in the center of the wing. Insert the control horn into the hole in the center of the aileron. Use a small about of glue to secure the control horn. Attach the servo arm to the control hole by the steel wire found in the kit.
Flap:
Do the same procedure as of did to the aileron servo, but to the servo hole furthest from the wing tip.
Aileron:
Flap:
STEP 7: Attaching Horizontal Stabilizer and Vertical Tail
Attaching Horizontal Stabilizer and Vertical Tail:
1. Horizontal Stabilizer:
Add glue to the furthest notch in the back of the fuselage, as seen in the picture, and place the horizontal stabilizer in the notch. Connect the control horn to the steel rod for the control surface.
2. Vertical Tail:
Add glue to the notch in front of the horizontal stabilizer, as seen in the picture, and attach the vertical tail to the fuselage. Connect the control horn to the steel rod for the control surface.
2. Vertical Tail:
STEP 8: Attaching Wings to Fuselage
Attaching Wings to Fuselage:
Insert carbon fiber rod into the right wing and fit right wing into the slot on the fuselage. Then, do the same to the left wing making sure to run the wires into the fuselage. Then place the screws in the holes at the bottom of the fuselage.
STEP 9: Assembling Propeller
Assembling Propeller:
Assemble the prop, found in the kit, to the motor shaft. This is shown in the pictures above.
STEP 10: Connect Electronics
Connect Electronics:
1. Plug in all wires to the receiver.
2. Plug the ESC into the battery.
STEP 11: Balance and Finished!
Balance:
The center of gravity is located 348 mm (plus or minus 6mm) from the front of the fuselage. I found that this is pretty much along where the carbon fiber spar is located in the wing.
Finished!
Balance:
Finished!
13 Comments
jwhssp 2 years ago
rlunaro 8 years ago
I have a question: you haven't detailed which motor did you exactly use. Can you tell us more about the exact model (shaft diameter, kv measures, diameter, inrunner/outrunner...). It seems to be an inrunner by the type of placement, but I am not quite sure.
noresponse 8 years ago
The Hobby King replacement motor is a 26mm brushless out-runner:: http://www.hobbyking.com/hobbyking/store/__25544__...
but you can use any 26mm to 28mm brushless out-runner with a range at least 100 watts on up. Heads Up RC ships for $2 in the US - I used their "Firepower Sport 400" on my Bixler 2: http://www.headsuphobby.com/Firepower-400-Sport-1150kv-Outrunner-Brushless-Motor-E-630.htm
MikeS525 7 years ago
Hello, is the Firepower 400 Sport motor you mention you use on your Bixler 2 more powerful than the stock motor?
Thank you
AvooOficial 9 years ago
Thanks for step-by-step!
I translate this in my site, ok?
http://www.avoo.com.br
msaltz 9 years ago
It seems that i have a problem that aileron on the bixler 2 is reversed and moving the aileron control on the remote left, raises the aileron on the right wing and lowers the left and vice versa. Any idea on how to fix this?
I am looking for a flight simulator that I can use with my bixler2 remote to practice flying. Any suggestions?
aunderwood1 9 years ago
I believe the aileron issue can be fixed with your transmitter, depending on which one you have. As for a flight simulator, I have a spektrum DX6i transmitter and was bought PhoenixR/C 4 w/ a cable. It was a lot of help. This worked for me but warning the program doesn't work on mac OS but can be used with windows OS on apple computers.
terryjw7 9 years ago
Nice thanks. Helped heaps. My first RC build.
asdex 10 years ago
jmessick 10 years ago
Tawhid K 10 years ago
aunderwood1 10 years ago
Bixler 2 Ready to Fly (everything you need included): $111
http://www.hobbyking.com/hobbyking/store/__39677__Hobbyking_Bixler_2_EPO_150_ mm_Ready_to_Fly_w_Optional_Flaps_Mode_2_RTF_.html
- Kit : $55
- DX6i w/ receiver: $200
- Servos: 4x$20 (this can be less)
- Battery: $20
- Charger: $40
- ESC: $20
- Motor: $15
Total : Around $450
*But you can go cheaper than this if your get less expensive electronics and radio
