Blinking an LED With ESP32
Intro: Blinking an LED With ESP32
The ESP32 is an advanced IoT microcontroller board possessing WiFi and Bluetooth Low Energy capabilities, as well as limited compatibility with the Arduino Core. This is the first module in a series of tutorials regarding the use of the ESP32 Development Board, from it's equivalent Arduino projects to advanced IoT projects.
The 'Blinking an LED' project uses the ESP32 Development Board will be used to blink an LED at a specific timed interval, infinitely. It is the essential fundamental tutorial for any microcontroller board, as it is the hardware equivalent of the classic "Hello World" tutorial!!!
STEP 1: Tools and Materials
- ESP32 Development Board
- 5mm LED
- 100Ω Resistor
- 3 pieces of jumper wires
- Breadboard
STEP 2: Circuitry
- Connect the negative pin (cathode) of the LED, indicated as the flat edge of the LED to ground, shown as the blue wire.
- Connect the positive pin (anode) of the LED, indicated as the rounded edge of the LED to a 100Ω resistor.
- Connect the free end of the resistor to pin D5 on the ESP32, shown as the red wire.
STEP 3: Coding
/*** * LED Blinking * Code Written by TechMartian */
const int ledPin = 5;
void setup() { // setup pin 5 as a digital output pin pinMode (ledPin, OUTPUT); }
void loop() { digitalWrite (ledPin, HIGH); // turn on the LED
delay(500); // wait for half a second or 500 milliseconds
digitalWrite (ledPin, LOW); // turn off the LED
delay(500); // wait for half a second or 500 milliseconds }
9 Comments
tonyho722 2 years ago
https://content.instructables.com/ORIG/FAA/SC8M/J5V3S0F2/FAASC8MJ5V3S0F2.png
john henry 3 years ago
hekoman 3 years ago
the seller wasn't clear and listed 5 of them making it very confusing.
bbogdanmircea 4 years ago
I don't think the delay is a nice example as this stops the processor
abhijeet_dp 5 years ago
steveinjava 5 years ago
Using the Arduino IDE, what device do you call this module...there are several ESP32 devices listed and none seem to connect for me...Txs in advance
SeemabF 6 years ago
Hi which software you have used for ESP-module test_bed drawing
SebastienH12 6 years ago
Wrong resistor value, preferred output is 6mA only.
