Blow Your Own Air-horn
Intro: Blow Your Own Air-horn
Most sports-fans are familiar with the extremely loud air-horns powered by a can of compressed air.
This Instructable tells you how to make your own air-horn from common house-hold scraps.
With a little practice, each air-horn takes under five minutes to make, so an evening's work can produce enough air-horns for even the largest family to enjoy around the Christmas table, or to dole out as party-favours so that the dear little ones can take some of the party fun home to the parents who didn't help arrange the party... ;-)
STEP 1: Equipment and Materials
A sharp knife or scissors with a pointed blade.
A 35mm film cannister or similar plastic pot.
A balloon.
A straw.
(You'll probably have to buy the balloons and straws, but you can scrounge film cannisters from your local photo-developing store. I get 20 or 30 a time from our local "Boots".)
A balloon.
A straw.
STEP 2: Drilling.
The air-horn needs two holes, one for air to enter, one for it to leave. The exit hole, in the centre of the cannister's base, is most critical, since it needs to form an air-tight fit around the straw.
If you pause and check the fit every few turns, you should reach a point where the straw can be pushed snugly in without being crushed or distorted.
Drill a second hole in the side of the cannister, roughly the size of the hole in the base. Scrape the edges smooth, as this is where your mouth will be going.
STEP 3: The Diaphragm.
Air-horns have a vibrating diaphragm to generate the sound. In this version, the diaphragm is a balloon.
Take an ordinary toy balloon and look at it. You should see that it has a crease around it. Since the diaphragm works best when it is flat, cut the balloon in half along the crease.
STEP 4: Optional Step - a Big Hole in the Lid.
The air-horn works perfectly with a whole lid, but you may find it easier to adjust your first air-horn if you can see the diaphragm.
To this end, cut a big hole in the middle of the lid.
That's it. End of step.
STEP 5: Assembly.
Lay the balloon over the top of the cannister and put the lid on so that it is pulled fairly tight. If you have a hole in the lid, you will be able to check that the balloon is smooth and tight.
Slide your straw into the bottom of the cannister until it presses against the diaphragm. Again, if you have a hole in the lid, you will be able to see where the end of the straw ends up.
That's it. The air-horn is made.
Go on, try it. Pucker up to the hole in the side and give it a blow.
STEP 6: It Doesn't Work?
If you're lucky, the horn will sound first time. Well done.
If all you get is a feeble hiss, keep blowing and gently nudge the straw harder against the balloon by tapping against the end of the straw.
On the other hand, if you just get silence and bulging cheeks you need to pull the straw out very slightly.
STEP 7: Hacking the Make.
I know you. If you're reading this, you probably won't stick to the basic instructions. You're probably already wondering if that plastic pot you keep your nails in would do the job, and you're fairly sure you've got an old rubber glove somewhere...
Yes, they probably will work. Film cannisters and balloons were just the easiest materials I had to hand, but I've also made one with a plastic snack pot and using the palm of a disposable rubber glove for the diaphragm.
Could you make one from a bucket? A dustbin?
What about the air supply? Blow too hard, for too long, you'll start seeing stars and have to have a nice sit down.
I made a basic model with a small inlet-hole, so it was a snug fit for the needle adaptor of a bicycle pump. That worked, honking nicely for every push of the pump. A larger stirrup-style pump I borrowed had a small air-reservoir, and with practice that gave a steady drone.
Tuning? What about tuning?
I haven't looked into this properly yet, but the note seems to be linked to the length of the tube you use, the tube's diameter and the tightness of the diaphragm.
Can you make it play a proper note? Could you make it tuneable?
Go on, enjoy yourself and don't annoy the neighbours too much ...
80 Comments
Kiteman 7 years ago
Oh, wow - ten years later, this project is still inspiring Makes.
Go see:
http://www.msraynsford.blogspot.co.uk/2016/08/nois...
Kryptonite 15 years ago
Kiteman 15 years ago
crapflinger 17 years ago
Kiteman 17 years ago
pyro13 16 years ago
Kiteman 16 years ago
blugyblug 15 years ago
acer73 16 years ago
arthaha 17 years ago
PKM 16 years ago
henryqiu 9 years ago
You took this from KipKay, you should give him credit
Kiteman 9 years ago
How did I steal it when I published two YEARS before he did?
I know the camera angles look the same, and so does the layout of each shot, but that's not because I stole the idea off Kipkay, it's because Kipkay stole the idea off me (he's known for stealing ideas and not giving credit, check him out).
Dumchicken 13 years ago
Kiteman 13 years ago
I avoid Kipkay's projects, as I prefer to read original work.
I published this two years before Kipkay posted "his" horn.
Who do you think copied who?
