Blowing Up Stuff With Capacitor Bank!
77K90291
Intro: Blowing Up Stuff With Capacitor Bank!
Don't try this at home.
I dug up some capacitors in the basement and decided to hook all of them up in parallel and see what happens when I short them out through different objects.
Stupid you might say, and it is. I'll probibly die of eletricution someday if not today....
STEP 1: What Happens When You Hook It Up to 0.7 Pencil?
What happens when you hook it up to 0.7 pencil?
I saw in Popular Science that if you run low voltage and high current through carbon graphite rods, you will create a very intense light, that could possibly blind you if your not wearing welding goggles.
I tried it out with 0.7 pencil led and it was SUPER COOL~.
First the by-products in the led burst on fire, and then the whole piece was glowing intense red, and it seemed to sharpend the end of the led. Later I can product insanely intense light that is brighter than a camera flash with the sharpened end!
Please post more stupid or crazy ideas I should try.
STEP 2: Hooking It Up to an LED
NEVER HOOK UP AN LED TO ONE OF THESE THINGS OR A 9 VOLT BATTERY!!!
I first connected an LED to the cap bank in reverse, it got really hot and started to sizzle, and it stinks really really bad. Then I connected the LED in the correct polarity, and it blew up as soon as I connected the wire. The outer layer of LED blow up like a bomb, flying everywhere.Good thing I was waring my goggles, because 1 piece shot right at my eye.
Then I tried to hook up a LED to a fresh 9 volt battery, and it also exploded. Very cool.
Sorry no pictures.. The led exploded too quick for me to take a snap shot, I'll post an exploded led on here sometimes soon.
STEP 3: Fun With Tin Foil
Here is what happens when you short out the cap bank with tin foil.
296 Comments
Where can you find this type of capacitors ? Is there anything I can dig into and take apart to pull something so big?
If not where is a good place to buy them?
It surely isn't brighter than a camera flash, they have more than 10kW usually
 WOW nice one!!!
what whode happen if i user 2.5v 120F caps??(yes 120F caps!!!)
is it will be strong like this to?
No, supercaps have a very high ESR.
Ive seen capacitors rated at 2.5vdc and 3000F!!!!!!!!!!!!! :)
I'm pretty sure you already know this, but wouldn't a switch let you set it off from a safer distance?
no then the switch would arc and shock his hand defeating the entire purpose
You could use a SCR to switch the currents, it would be a lot safer then just touching two wires together.
try makeing a coil gun with these caps
I think that would be a coil gun that falls into the artillery class of coil guns.
No. The one I'm building would. I'm using a 13,900 Joule Bank. 400v. I'm already scared.
THAT IS AWESOME!
*runs off to connect the led to a 9v with a switch, and package it all up like a gun*
i made a capacitor bank out of disposable camera capacitors and i hooked it up to little metal rod and some how idk how,but the little rod shot at my palm almost going to through the other side.... i have no idea how this happened but i wasnt too happy about my ER bill... just a little warning..
That is called the railgun effect.
i thought you needed a electromagnet to create a coil gun
The electromagnet effect can be created by many things.
but there has to be a coil of wire, or other conductive material. right?
More Comments
