Bluetooth Control RC Tank + Android + Arduino
Intro: Bluetooth Control RC Tank + Android + Arduino
May peace be upon you
This is my first instructable. It is about controlling your rc tank via bluetooth instead of using radio frequency. There are many project like this but this is my way. hahaha
I started to think that I am so lazy to bring the controller of the rc tank. So I got the idea to make one that can be controlled by my smartphone. The big advantage is that you can add whatever feature to your tank and the smartphone is the thing you bring anywhere anytime.
Here are the main things that I used.
1) Bluetooth module HC-06
2) L298N Motor driver
3) Arduino Uno or Nano
4) RC Tank
5) smartphone with bluetooth
6) Android Controller app
STEP 1: Preparing Android Application
By using MIT App Inventor, I have build a simple application that send a command in ASCII to the Arduino via Bluetooth. The app use of canvas, image, label, button, clock and bluetooth connectivity. It consists of 13 different command image (canvas).
As we press and hold the command image (canvas), the data is send until we release it. The data is then compared with the Arduino coding. If the data is same, then an action is taken. If not same, no action taken.
download the app below and install it on your phone.
and if you want to add some more features, you can download .aia format below. Open the MIT App Inventor and import the folder.
STEP 2: Remove the Existance Circuit
Carefully remove the circuit inside the tank. But be sure that you labelled them first as they might be use in the future. For easier, take the picture of the circuit connection.
STEP 3: The Arduino Circuit
Note that as I read through some websites, the Pin Rx of the Arduino should be connected to voltage divider first to get a value about 3.3V before connect it to Tx of the Bluetooth module. But I have directly connect them together and until now there is no problem happen yet... wahahha
For testing, you can replace the motor with LED or other output.
STEP 4: Pairing Smartphone With Bluetooth Module
After connected all the wires, turn on the Arduino. You will notice that the Bluetooth module is now flashing. This is because it is not connected to other device yet.
Then go to your smartphone, turn ON bluetooth and search for the module. The name of the module is "HC-06". Pair the module and if it ask for the password, it is "1234".
STEP 5: Uploading Arduino Coding
Copy and paste into Arduino IDE.
Now, it is time to upload the coding into Arduino.
Dont forget to disconnect the Rx and Tx wires during uploading. If not, the uploading will fail.
After uploading done, reconnect the wires again.
STEP 6: Testing
Now you have reached the final stage.
Activate the bluetooth on your smartphone. Then, open the app that you have installed earlier.
Click the button "select device"
A list of bluetooth device will appear and choose your Bluetooth module. In this case, HC-06.
wait a moment and if the connection is successful, the Bluetooth module will stay lighting and it will pop out
"the device is connected"
Press any image from 13 different them. You will see there is an action take place on your RC tank. Test all of them.
STEP 7: Put Them Nicely in Your RC Tank
This is the way to make your RC Tank neat and tidy. Depend on your creativity.
I used the recycle item as much as possible such as:
-the aluminum plate remnants
-USB female, internal hard disk casing from damage laptop
-audio jack male and female from broken radio and microphone
-some jumper wire from broken electrical appliance
24 Comments
Robotkuning 3 years ago
int motor1Pin1 = 12; // pin 2 on L293D IC
int motor1Pin2 = 11; // pin 7 on L293D IC
int motor2Pin1 = 10; // pin 10 on L293D IC
int motor2Pin2 = 9; // pin 15 on L293D IC
danihot26 4 years ago
jeneral 4 years ago
The connection can be found in the link you provided. Im not sure about this module pinout. But based on the picture, it used three PWM inputs and one digital input. If you want to add another l298n module, you can use arduino uno pinout 3,5,6 for PWM and just choose any one digital output.
Aadhav2304 7 years ago
jeneral 7 years ago
You can buy online on website above
But i suggest you to go to your nearest electronic shop. Just give them the module number l298n and they will find it for you
totowp 7 years ago
Hey jeneral... can you give me information how to matching button in canvas (appinvertor) and pinOUT (arduino). ?
because i want add some button for moving relays.. thanks..
I see that
w = forward
d = backward
q = left
e = right
how to setting the STATE ?
jordan the tamago 8 years ago
i wonder where u bough that tank... its look very nice!
jeneral 8 years ago
cool, can u share the link?
jeneral 8 years ago
http://www.lelong.com.my/m1a2-abrams-type-90-1-24-...
but they only ship within malaysia
FulkitN 8 years ago
As i am a beginer this diagram i am able understand it
jeneral 8 years ago
KronoNaut 9 years ago
I am really looking forward to making this!
jeneral 9 years ago
I was able to jump back into this project after being busy with other things for a few months. I was able to get the lower half working via the usb cable to the Arduino. Next step is to hook up the upper half, then the bluetooth module. Step by step it is coming together.
I wanted to add that I am using L298 Motor Driver Modules instead of just the chip. It makes hooking up the Arduino and motors easier. I am lucky enough to have a local supplier. You can get them here:
http://www.vetco.net/catalog/product_info.php?cPath=640&products_id=14337
KronoNaut 8 years ago
I got it to work. I had trouble with the communication between my Arduino and the Bluetooth. Fixed that by combining your sketch with the Sparkfun Bluetooth test sketch by Jim Lindblom. I am putting together my documentation and will be posting it on instructables. You were a great inspiration.
HumzaU 9 years ago
Hi, i am making a slightly modified version of this (basically a car without the turret and horn, just a basic forward, backward, left and right function car). I tried to slightly change your code for the arduino uno but... Arduino gives me the following errors... I have no previous experience with this type of coding however i can easily get a general feeling of they work.
"sketch_feb10b.ino:1:21: error: pitches.h: No such file or directory
sketch_feb10b.ino: In function 'void loop()':
sketch_feb10b:23: error: 'state' was not declared in this scope
sketch_feb10b:26: error: 'state' was not declared in this scope"
the changes i made to the code are:
#include "pitches.h"
int motor2Pin2 = 9;
void setup() {
// sets the pins as outputs:
pinMode(motor1Pin1, OUTPUT);
pinMode(motor1Pin2, OUTPUT);
//pinMode(enable1Pin, OUTPUT);
pinMode(motor2Pin1, OUTPUT);
pinMode(motor2Pin2, OUTPUT);
Serial.begin(9600);
void loop() {
//if some date is sent, reads it and saves in state
if(Serial.available() > 0){
state = Serial.read();
// forward
if (state == 'w') {
digitalWrite(motor1Pin1, HIGH);
digitalWrite(motor1Pin2, LOW);
digitalWrite(motor2Pin1, LOW);
digitalWrite(motor2Pin2, HIGH);
// left
else if (state == 'e') {
digitalWrite(motor2Pin1, HIGH);
digitalWrite(motor2Pin2, LOW);
// right
else if (state == 'q') {
digitalWrite(motor1Pin1, LOW);
digitalWrite(motor1Pin2, HIGH);
// backward
else if (state == 'd') {
// Stop
else {
noTone(13);
delay(100);
Could you please help me where i have gone wrong this is for a school project thanks >.<
jeneral 9 years ago
I have uploaded the new tank.ino code..
If you dont want to use horn function, you can remove
"#include "pitches.h"
