Bluetooth Speaker Boombox
Intro: Bluetooth Speaker Boombox
Hey friends,
In this instructable, I will clearly explain to you how to create a multimedia Bluetooth boombox speaker at home.
This boombox is created using PVC pipe and parts basically. All other electronic parts are mostly salvaged from my electronic junk collection.
Let's have fun with this amazing project!
STEP 1: Prepare PVC Pipe
Cut the 4" PVC pipe at 4 feets
Cut middle control panel at 4" from each side.
*Please watch the video for a clear demonstration
STEP 2: Preparing PVC Plates
- Heat PVC parts using a heat gun or gas stove
- Flatten them by applying pressure between two tiles
- Mark control panel parts and cut
STEP 3: Glue Front Panel
- Glue front panel plates
- Mark cutting points for controls
Please refer to the video
STEP 4: Cut Two End Caps
- Mark end caps line and cut off the excess parts
STEP 5: Cut Air Holes of Speaker Mounts
- Use a CNC router or a manual method to cut two end caps design
- Cut passive radiator diaphragm
STEP 6: Mount Speakers
- Solder speaker wires, and mount speaker on speaker brackets prepared
- Apply covering brackets
STEP 7: Prepare Electronics
- Prepare amplifier circuit
- Disassemble salvaged battery pack
- Connect batteries to BMS module
- Solder volume controls
STEP 8: Cover the PVC Casing
- Cover the PVC casing using the black rexine.
- Use glue and a heat gun to get the shape
STEP 9: Preparing the Passive Radiator
- Cut off the magnet of the old speaker
- Cut the diaphragm
- Glue diaphragm to speaker
STEP 10: Prepare the Front Control Panel
- Use CAD software and CNC to design the front panel and cut. You can also manually cut the panel.
- Attach the Bluetooth USB module to the front panel
STEP 11: Mount Belt and End Caps
- Cut belt mounts using CNC, and mount the belt.
- Mount all parts inside, and close with speaker end caps
*Please refer to the full video instruction
STEP 12: Done!
- Enable Bluetooth on your mobile phone
- Connect to the device
- Play & Enjoy!
Hope this project is useful to you friends. Please leave your comments regarding the project, so It's a big help to me to improve future DIY projects. Please watch the complete video of this DIY project below.
Thank you very much.
