Introduction: Bluetooth Controlled Arduino Robot Arm
I finally added bluetooth capability to my arduino robot arm. I did that using the HC-06 bluetooth module.
Step 1: Requirements
-Arduino 6-dof robot arm
-arduino uno or due
-SSC-32 servo shield
-HC-06 bluetooth module
I am not going to explain the robot arm setup, the different boards and modules that i have used and the powering of the system, because i already did that in previous tutorials that you can find here:
Controlling servos with SSC-32
Step 2: Video
You can watch the video on this link bluetooth controlled robot arm
11 Comments
Question 3 years ago on Introduction
Sir can we use this same programming only for Arduino Uno without using SSC-32
5 years ago
would I be able to make this voice activated and program a set of pre programmed voice commands and or protocols into it? if so where would I start and how should I go about it?
7 years ago
hello yhtomitsy, I can't access arduino-hacks.com
7 years ago
Nice one. I like the way it look.... :D
7 years ago
Cool job! I really appreciate it! I want to learn more set ups about the bluetooth module, while the link is not available now. Could you update it? :D
7 years ago on Introduction
Nice one. Thanks for sharing a lot.
8 years ago
this project needs a kit using which any one can make the model. its easy to build but good.
8 years ago
Wow!!
8 years ago on Introduction
That's definitely interesting. Would it be possible to make this arm run from a cellphone using accelerometer or IMU if available for the control of arm motion?
Yes it is possible to control the arm from a cellphone using accelerometer or IMU. Here is a tutorial that shows a robot arm being controlled using a gyroscope
https://www.youtube.com/watch?v=ai2RiGMyV08
That's really awesome! Thanks for sharing your process!
