Introduction: Bolt Action Knex Gun
this is a small basic knex gun that has some never before seen features.
it is bolt action with a (i call it a percussion cap) that when struck by the ram it will shoot whatever
is in the barrel out with force
Step 1: Parts List
you will need these parts to make this gun
16 gray pieces
5 orange pieces
2 yellow pieces
1 lime green piece
1 knex hand
1 blue rod
1 yellow rod
1 black rod
and the elastic/s of your choice
16 gray pieces
5 orange pieces
2 yellow pieces
1 lime green piece
1 knex hand
1 blue rod
1 yellow rod
1 black rod
Step 2: Make the Barrel
start by attaching one orange piece to the end of the black rod and then add 8 gray pieces right behind the orange piece. next take one gray piece and turn it sideways and attach it.
now put the knex hand in the end of the barrel and attach the lime green piece and a gray
piece right after it.
Step 3: Make Hand Hold and Trigger
start by attaching one orange piece just like the other gray piece in the last step.
next take 2 gray peices and attach them behind the hand hold. after that take a orange piece a slide it down the black rod to the gray pieces then attach a gray piece behind the trigger.
Step 4: Make the Ram
take the yellow rod and put a orange piece on one end and attach a gray piece infront of it
Step 5: Make Rear Sight and Slide
take the half finished gun and add one more gray piece to the other gray piece behind the trigger.
then take 1 yellow piece and attach on the bottom of the gun and add a orange piece behind it.
take another yellow piece and a gray piece and clip them each other. take this piece and attach it to the black rod
Step 6: Insert Ram Into Gun
slide the ram into the back of the gun
Step 7: Add Elastics
add the elastics as shown in the picture
Step 8: Add Slide Elastic
wrap elastic around this area. go to next step for next picture
Step 9: Slide Elastic Part 2
now loop the elastic around the front of the gun and wrap around the gray piece thats in front of the hand hold
Step 10: Done
there you made it and now you can fire it.
pull the slide back like this and put something in the barrel and pull the trigger
