Introduction: Boo the Crochet Ghost Solid Granny Square
Here is the Pattern for Boo The Crochet Ghost Solid Granny Square. There are just so many varieties and possibilities to use the Granny Squares. This little Ghost Square is easy and quick to make. The pattern starts by making a Crochet Ghost Applique , which is turned into a Solid Granny Square. The Solid Granny Square pattern ensures no visible gaps and holes in the finished project.
These Granny Squares can be made in any size of your choice. Just keep adding the repeat Stitches to the square and you can make them as large as you want. You can join these Ghost Squares to make Pretty Crocheted Blankets. These Squares would also be great for making Halloween Themed Tote Bags, Pillows, Tablemats, Coaster, Clothing Accessories and just many more options. Use These Ghost Squares to put a Special Halloween Ambiance to your place.
5 inches - Customizable to any size
Visit https://rajiscrafthobby.blogspot.com/2023/09/boo-crochet-ghost-solid-granny-square.html
8 Ply Yarn
4 mm Crochet Hook
Step 1:
Here is the Video Tutorial:-
You can follow along with this tutorial video. Please be sure to subscribe too!
Step 2:
Round 1:- (Face)
Start with a Magic Circle.
12 Double Crochets in the circle.
Pull the yarn end to close the gap.
Slip Stitch on top of the first Double Crochet.
Step 3:
Round 2 (Arm 1):-
Chain 4.
1 Slip Stitch into the Second Chain from the hook.
1 Single Crochet each in the next 2 stitches.
Slip Stitch on top of the first stitch i.e . the First Double Crochet.
Step 4:
Round 3 (Body):-
Chain 8.
1 Slip Stitch in the Second Chain from the hook.
1 Slip Stitch in the next stitch.
1 Half Double Crochet in the next stitch.
1 Double Crochet in the next stitch.
1 Treble Crochet in the next stitch.
2 Treble Crochets in the next stitch.
1 Treble Crochet in the last stitch.
Skip 1 Double Crochet Stitch.
Slip Stitch on top of the next Double Crochet.
Step 5:
Round 4(Arm 2):-
Chain 4.
Slip Stitch into the bottom of the same stitch.i.e. on top of the Double Crochet and weave off.
Step 6:
Round 5:-
**This Round, we will be working only in the Back Loops.
Join the new Color Yarn into the Back Loop of the First Stitch.
Chain 2.
2 Double Crochets in each stitch around.
Join the 1st Arm along with first Double Crochet and the align the 2nd Arm accordingly and Join it while making the Stitches.
Slip stitch on top of the first Double Crochet.
24 stitches.
Step 7:
Round 6:-
Chain 2. 1 Double Crochet in the same stitch.
2 Double Crochets in the next stitch.
Repeat(1DC, 2DC).
Change the yarn color while making the slip stitch.
36 Stitches.
Step 8:
Round 7:-
Chain 2.
(2 Double Crochets , Chain 1, 2 Double Crochets in the next stitch) - that's the 1st Corner made.
1 Half Double Crochet each in the next 2 Stitches.
1 Single Crochet each in the next 3 Stitches.
Repeat((2DC,Ch1,2DC in the next St),1HDC*2,1SC*3,1HDC*2)
44 Stitches, 4 Chain 1 spaces.
Step 9:
Round 8:-
Chain 2.
1 Double Crochet in each stitch untill you reach the Corner.
In the Chain 1 Space make - (2 Double Crochets, Chain 1, 2 Double Crochets)- that's the corner made.
Repeat(1DC in each stitch untill corner),(2DC,Ch1,2dc)-in corner stitches)
Step 10:
Round 9:-
Chain 2.
While making the last set of Double Crochets , join the Tail end of the Ghost along with the stitches.
Slip Stitch on top of the first Double Crochet and Weave off.
***If you wish to make a large size square, then keep repeating Round 9 untill the size needed.
Step 11:
Eyes:-
Using a Yarn needle, sew the eyes with a Black Color yarn.
Halloween Contest
