Boot Dryer
Intro: Boot Dryer
cheap DIY boot dryer with parts from a leftover plumbing project
STEP 1: Parts Needed Are
four, 2"elbows .95c each
two, 2" T's $3.11 each
one, 2" Y 3.11
one, 2" fernco ci/plastic/copper/steel to ci/plastic/copper/steel
and at least 3 feet of 2 inch PVC pipe
one, 2" Y 3.11
STEP 2: Cutting and Assembly
cut 1 length of PVC pipe 16 inches long then cut the 16 piece in half at a 40° angle like so on the first picture. then cut wedges about an inch above the angled cut like the second picture this will help unrestrict airflow when inside the boots
STEP 3: More Cutting
cut seven 2 inch PVC sleeves 2 inches long and connect everything together and (glue) them in place as seen in the picture above
STEP 4: You Are Almost There Don't Stop!
next is important "do not glue your 8 inch angle cut lengths together just shove them in you're 90°elbows as seen above. you will understand why later
STEP 5: Start Installing
(NOTE) nothing else will be glued so put it away so you don't get overzealous and get ahead of yourself.
shove the 2 arms into one of the T's (no glue)
next shove the remaining 2 elbows into the last remaining T (no glue)
then connect the T's to the Y (no glue)
add the fernco and a hair dryer then tighten the clamps
having a non glued connection on the rest of the parts allows the boot dryer to be adjusted to different sizes of boots shoes gloves hats and it also allows it to be torn down and stored
STEP 6: Ways to Use the Boot Dryer
FYI the hairdryer attached to the Y is directional. so whatever you think will take longer to dry you want to point the hairdryer towards
there are 4 setting on the hairdryer
high, low, cool high and cool low. in order to use the cool air functions you have to tape the cool button in the on position and select the high or low setting
I made this boot dryer 2 years ago. I have used all the settings and the PVC has held up beautifully.
the only complaint I can give you is it isn't quiet but it dries fairly quick!
16 Comments
Left-field Designs 8 years ago
drosenkranz 7 years ago
cornfed1230 7 years ago
thefrenchmaker 8 years ago
very cool! on the todo list !
buck2217 8 years ago
Cool but does the smell of the boots permeate everywhere!!?
9787538 8 years ago
FranciscoG47 8 years ago
asi2007_ukr_net 9 years ago
very original, cheap and easy!
ncage1 9 years ago
drosenkranz 9 years ago
Garland_Key 9 years ago
Those look like military issue Belleville boots with Gortex lining - nice boots! Nice hack - I might try this hack when I go back up north.
NathanSellers 9 years ago
PBrackley 9 years ago
linolino 9 years ago
Ysabeau 9 years ago
Very clever!
