Bottle Rack Made of Scrap Wood
Intro: Bottle Rack Made of Scrap Wood
This bottle rack is made of scrap wood.
Sometimes I get little pieces of swiss pine from a friend. These wood is very expensive and it's a shame to burn it even the pieces are to small for normal furniture. This bottle shelf is a perfect project to use all this small pieces to make a great looking rack.
Tools
- table saw
- edge sander (or sandpaper)
- random orbit sander (or sandpaper)
- cordless drill (or normal drill)
Misc
- linseed oil
- 9 screws 3 x 40 mm
- 2 screws 6 x 60 mm
STEP 1: Sawing
I saw 18 long, square pieces and 18 short.
STEP 2: Sawing the Tenon I
The short pieces got a tenon
I lowered the table saw blade to the thickness of the pieces.
Then, with my tenon jig, I saw them on every end two times.
STEP 3: Sawing the Tenon II
Then I lowered the table saw blade to the middle section and cut all the shoulders away.
STEP 4: Sawing the Mortise
For cutting the mortise I moved my jig exact for the thickness of the table saw blade to the right.
After cutting each piece twice on both ends I moved the jig again to remove the middle section
STEP 5: Gluing
I applied wood glue only on the tenon and put the pieces together.
STEP 6: Sanding
I sanded all the pieces with my edge sander.
The inner edges of the little frames were sanded with a random orbit sander
STEP 7: Cutting the Backboard
The backboard has many knots and imperfections for normal furniture but for me it is beautiful.
STEP 8: Making Grooves in the Backboard
On my table saw I don't have a cross cut sled it is only a cross cut board.
I put a little piece of wood in a slot and adjust the distance to 11 cm
I made a first cut and then I placed the first cut onto this little finger.
Thereby the distance of all cuts are the same.
Then I made a second cut of each groove in the same way.
At last I removed the center of the middle section.
STEP 9: Drilling Holes
I drilled holes through each groove and countersinked them from the back.
I also drilled two mounting holes and countersink them.
STEP 10: Finish
I oiled every part with linseed oil and after half an hour I removed the oil with a paper towel.
STEP 11: Assembling
I put always one frame left of the center and one right of the center.
Then I screwed the frames on the backboard without glue.
I had no idea how it looks like and so I have the option to change my decision.
At last I screwed the shelf on the wall.
STEP 12: The Result
Instead of thousand words, please watch the video
If you like it, I am glad if you vote for it in the Shelving Contest 2016
If you want to see more of my work, subscribe to my Youtube-channel
4 Comments
raorn 6 years ago
Awesome, I like it a lot! Need something like that on my wall, want to build it myself.
I only have one concern - "Then I screwed the frames on the backboard without glue". Can it hold the bottle weight? One screw, from behind, no glue... Doesn't seem it can hold much weight. Please tell me I am over-cautious.
StephanP1 6 years ago
Thank you. It is very strong, believe me. But you can try it with a heavy weight. A bottle of wine is ca 1 kg. so try it with 5 kg of sugar or what ever you have.
Verga 7 years ago
Great job, Please do an instructable on your tenoning jig.
I voted for you on the Trash to treasure.
StephanP1 7 years ago
Thank you. The tenon jig is on my list, coming soon.
