Bottlecap Monopod
Intro: Bottlecap Monopod
It may not be original, but it works. The bottlecap monopod can be attached to any water bottle, and of course costs only under 50 cents. It was made out of trash, litterally, but is just fantastically functional. Also, please excuse any blurry photos because I had to work fast due to low battery.
STEP 1: Parts
Parts:
1 1/4 inch bolt 1 inch long
2 Nuts to match
2 Small washers, 1/4 inch
1 larger washer, 1/4 inch
1 Bottle cap
Tools:
Screwdriver (phillips)
1 ratchet head to match nuts
2 Nuts to match
1 Bottle cap
Tools:
STEP 2: Making the Hole...
Use the screwdriver to make the hole inside the bottlecap, making sure that you go from the inside out, then screw the bolt in.
STEP 3: Final Touches...
After attaching the bolt, attach the componets in this order:
nut
small washer
small washer
large washer
nut
Then, fasten using the ratchet bit and screwdriver.
nut
small washer
small washer
large washer
nut
STEP 4: Your Done!
Now, screw into your camera gently. If the it doesn't fit, the bot is too big, or you have some kind of alien camera.
Anyways, thanks for reading!
4 Comments
woodycanuck 13 years ago
jwoo2023 13 years ago
josh123 13 years ago
Great Ible
Kiteman 13 years ago
Make it with a cola cap, and you have a monopod for any party...
