Introduction: Boyo Brick - the Pins & Holes System!
Want To Make A Project, But You're Not A Fan Of The Way Legos Stick Together? Well, Download The .stl File, & Go To Vectary, & Start Designing, Or You Could Print It Thoroughly. I Invented The "Stud-Into-Tube" Design! You Could Redesign It, Buuuuut, It Would Lose It's Function. If You Print It, It Needs Another Brick To Go On, & Another, & Another, & Another, etc.
If You Could Describe It, It Could Be Different Than Other Legos, & In Fact, The "Stud" Is Called A Pin, & The "Tube" Is Called A Hole.
Onto The Steps!
- Good 3D Printer
- Vectary (Optional)
- .stl File
- Something To Help The 3D Printer Print
Step 1: Download the STL
Download The STL To Get It Ready For Printing.
Step 2: Open Your Program
I Use Vectary To Make The STL, & Share My STLs. Open Your Favorite Program To Edit (Optional), Print, Or Just Look At The STL. I Have The STL File Here.
Step 3: Print Your Baby (Brick) Into the World
The Brick (The "Baby") Needs A Breath Of Air Someday, So Why Not Print It Into Your World? Use A 3D Printer That Is Big, Not Too Big, Nor Too Small. It Needs A Big Enough & High Enough Quality 3D Printer. Use Blue Material For It, That Way, It Will Be Blue.
Anything Goes Contest
