Brass Knuckles
Introduction: Brass Knuckles
About: I Like to build things, make funny pranks and many more things.
This instructable will show you how to make brass knuckles. Brass knuckles are also known as B-knucks or knuckle busters. And know that I'm not showing you how to make these to hurt anyone, unless it's self defense. For this instructable you may want to wear gloves. You can buy all of the materials that you will need at a local hardware store.
Materials-
Brass or Copper pipe
Pipe cutter
Vice
Spray paint(optional)
Sand paper
Saldering iron / a blowtorch will also work
Solder
Flux
Step 1: Cut the Pipe
Start by putting the pipe in the vice and cut 4 even rings.
Step 2: Soldering
Now take a blowtorch or a soldering iron and solder the rings together. After soldering two together grab them with pliers and dip them in cool water to cool them off. After you have a pair of two rings soldered together, solder the two pair together.
Step 3: Clean
Next just get a rag and some water and clean off your brass knuckles
Step 4: Dull
Now you need to take the end of your pipe cutter and dull up the inside of your brass knuckles so they don't hurt your fingers as much when you wear them.
Step 5: Paint (optional)
Next you just need to spray paint your brass knuckles. I like to paint them either gold or silver.
After that, your done.
Enjoy :)
Be the First to Share
    • Toys & Games Contest
    • Furniture Contest
      Furniture Contest
    • Big vs Small Challenge
    5 Comments
    JTapp09
    JTapp09
    5 years ago
    The instructable isn't completely finished, I'm still making a palm support piece
    xpozitron
    xpozitron
    5 years ago
    Those pipes will have sharp edges. Cool way to cut own fingers. Usual brass knuckles also do have a palm support piece.
    xpozitron
    xpozitron
    5 years ago
    TheDevil13
    TheDevil13
    5 years ago
    Hate to break it to you but those don't look too reliable...
    The_knifemaker123
    The_knifemaker123
    5 years ago
    Test one: punch a wall with then resoder and put in a pommelpiecer
