Make a Brass Knuckles Spoon Through 123D Catch, MeshMixer & MakerBot.
Intro: Make a Brass Knuckles Spoon Through 123D Catch, MeshMixer & MakerBot.
This tutorial illustrates how to create a Brass Knuckles Spoon just in case a rowdy food fight breaks loose at your next dinner party.
I used:
-Autodesk 123D Catch to scan the image into CAD
-Autodesk MeshMixer to massage & patch up the CAD surfaces
-MakerBot Replicator to 3D print the spoon
-KeyShot to render the spoon
I used:
STEP 1: Materials You Need
For this project, you need:
-an iPad with Autodesk 123D Catch app (free download here)
*you may use a digital camera & Autodesk 123D Catch for online or PC instead
-brass knuckles (I used these plastic UrbanHooker fishing brass knuckles)
-a plastic spoon
-some fishing line
-a small amount of clay
-a pair of scissors
-you'll also need a computer with Autodesk MeshMixer software (free download here)
*optional:
-access to MakerBot Replicator
-KeyShot software
-a plastic spoon
-some fishing line
-a pair of scissors
*optional:
-KeyShot software
STEP 2: Cut & Attach the Spoon to the Brass Knuckles
Cut the handle of the plastic spoon & attach to the brass knuckles with the clay.
STEP 3: Hang the Brass Knuckle Spoon
Tie a loop around the brass knuckles with the fishing line. Attach the the other end of the fishing line to something above so it hangs over the surface of a table. The spoon should hang so that the tip just touches the table surface.
*note-I attempted to shoot the 123D Catch with newspaper as the background for a better catch. This method proved to not work well. My second catch attempt without the newpaper & the wood grain of the table as the background worked much better. Please read tips for a better catch here.
STEP 4: Photos for 123D Catch
Using the iPad (or digital camera) open the Autodesk 123D Catch app. Take photos of the brass knuckles spoon. You should start at a low angle & progressively increase the height of the camera. Move around the spoon in about 15-20 degree increments for each photo. Use the maximum of the 30 allotted photos for a more accurate catch.
STEP 5: Process the Catch
After you finish taking all of the photos, save & process the catch. You may have try a few catches with 123D Catch before you get one you are happy with.
STEP 6: Import Catch Into MeshMixer
Download the file as an OBJ from 123D Catch. Import the OBJ into MeshMixer. There will be a lot of unnecessary surfaces you need to delete in MeshMaker. You can use the surface & volume brushes to massage the surfaces. The inspector tool is useful for patching up holes in the model.
STEP 7: 3D Print With MakerBot
Optional:
After all of the holes have been patched in MeshMixer so that it is a solid, you can now send it to the 3D printer. Open the file in MakerWare & position it on the platform. Send to the MakerBot Replicator.
STEP 8: 3D Print Complete
The final 3D print is done.
STEP 9: Render in KeyShot
Optional:
Open the OBJ in KeyShot & render as chrome.
Enjoy food fighting.
2 Comments
amandaghassaei 11 years ago
damonite 11 years ago
my initial idea was to make it in ceramic. The rendering "popped" the best when I rendered it in chrome though.
cheers,
Damon
