Break Barrel Air Rifle Trigger Fix
Intro: Break Barrel Air Rifle Trigger Fix
Triggers aren't too good on break barrel air rifles, usually the pull is heavy and annoying. Here's a trick that'll work on most break barrel air rifle with no permanent modifications required. It makes the pull more plush and lighter.
STEP 1: Start
Tools:
Phillips head screw driver
Small flat head screw driver
Pellet rifle
Alright so to start, remove the action of the rifle from the stock. There will be a couple screws to pull
Pellet rifle
STEP 2: Fix
Remove the trigger from the trigger assembly. You will find a small spring and a pin which is the sear for the trigger, discard the spring and take the pun and put washers over it (look at images) it'll make the sear bigger which will fix the deal.
STEP 3: Tips
You will notice a very light trigger pull amd be careful.
Tip: Washers can be found on the two bolts at the front holding the stock to the action
This shouldn't do any damage to your rifle and will hopefully improve your accuracy
7 Comments
YooHooty 5 years ago
JohnW814 5 years ago
BetiuskaM 7 years ago
You get a "hair trigger" doing this (fix) your air rifle can go off if dropped, this could be very dangerous.
Rahdzhillaxxx 9 years ago
gidder 9 years ago
essdee1972 9 years ago
seamster 9 years ago
Another good fix! Thanks!
