Breath Smeller
Intro: Breath Smeller
This is my update of the original "Personal-breath-smeller". This one has pictures. These are the materials that you'll need:
STEP 1: What to Do If Your Straw Is Bendy
If your straw is a bendy straw, simply cut off the bendy part.
STEP 2: Cut Your Straw in Half.
Cut your straw in half.
STEP 3: First Half
Take your first half. Cut a 45-degree angle off of one of the tips.
STEP 4: Second Half
Take the second half. Cut an oval on the side about 2-thirds of the way down.
STEP 5: Tape
Tape the 45-degree angle to the oval so that it is all a big tube.
STEP 6: Tape 2
Tape the tip of your tube shut.
STEP 7: Trim
Trim about 1 centimeter (1/2 inch) off of the top tube.
STEP 8: How to Use
Blow into the bottom tube. If you made it right, you should feel your breath going up your nose. Sniff as soon as you stop blowing. YOU CAN SMELL YOUR OWN BREATH!!!
19 Comments
maharg20 15 years ago
neubaten 16 years ago
chaoscampbell 16 years ago
Don't know why I didn't just add this in the first place and because I know you all love my multiple posts
Lftndbt 16 years ago
PwNzA 16 years ago
comment again!!!...
Sorry I didn't realise we were still on the topic.....
Believe me I understand your point of view.....
Your breath being your breath has certain aroma's to it, that are not generally detectable...
Your breath carry's with it aroma's produced in your mouth...
And the human body does not waste it's time interpreting smells it relates to itself....
So.... Ever had a piece of meat get stuck in your teeth and not notice till the next morning?
Did it go a bit rank overnight?
Theorectically does IT have an aroma? Yes... Rotting meat smell....
Add an absess to the senario and you have rotting meat and rotting tooth...
= smelly situation..... But what smells, the meat or the tooth it's stuck in and decomposing??
You seem to be hinging your argument on adding things to your mouth such as mint or other external stimulus being the culpret.... Yet what is the definition of bad breath???
Generaly speaking it is the odour that is carried on the breath....
So therefore all the micro-organisims in your mouth ... breaking down the meat and junk that get's stuck in your teeth...
This process is NOT instantanious as you suggest is the only way of smelly somethig different....
When can smell rotting material, so therefore we can also detects aroma's on your own breath....
By the way YOUR breath is not always the same.....In fact technically speaking it is NEVER the same due to us never or VERY rarely eating the same diet.... exactly day after day...
I agree it is not something that the brain activley analyses on a constant basis for change....
Odours are from external sources...generally.... wether it's a mint just popped in your month or bacteria dissolving all their caught goodies..
You can smell this!!!!
Your argument doesn't make sense.... And is flawed at it's most basic level.....
Go smell your breath some more....
bigfootduck 16 years ago
Fluid-Fire 16 years ago
dentsinger 16 years ago
GreenDay 16 years ago
