Bucket Mouse Trap (kill or No Kill)
Intro: Bucket Mouse Trap (kill or No Kill)
Catching mice is easy with a bucket mouse trap. Mice walk up the ramps, jump to the peanut butter which is applied to a round container and spins when the mice land on them. When you wake in the morning you'll either have drowned mice or, if you choose to not kill them, a bucket full of mice.
Happy Hunting!
STEP 1: Parts and Tools
Parts
5 gallon bucket
2" PVC coupler
2 X 2" PVC end caps
Wire hanger
You'll need something to use as ramps. We found some cardboard and foam board lying around the house. You can use yard sticks, small pieces of wood, or anything the mice can use to get to the edge of the bucket.
Tools
Drill
Small drill bit (the size of the wire hanger)
Pliers
STEP 2: Wire Hanger
The wire hanger should be wider than the bucket. Cut the long and straight part of the wire hanger using pliers.
STEP 3: Prepping the Bucket
Drill two small holes near the top of the bucket to thread the hanger.
STEP 4: Preparing the Roller
Assemble the roller by inserting the end caps into the coupler. Drill a small hole into the center of both couplers.
STEP 5: Threading the Wire
Thread the wire hanger that you cut through the holes in the bucket and the holes in the PVC end caps. Using pliers turn up about an inch at either end of the wire to keep the wire from sliding out of the bucket.
STEP 6: The Bait
Spread peanut butter evenly around the cylinder.
STEP 7: Finished
All you have left to do is lean a couple of ramps against the edge of the bucket. You can use anything as a ramp from yard sticks to cardboard (as shown in picture).
STEP 8: Kill or No Kill
Kill: Fill the bucket with 4" of water
No Kill: Plan on taking your bucket outside to free the mice that loved the peanut butter spread all over your new mouse trap.
8 Comments
DaveT2 3 years ago
First, if you release the mice anywhere near the location where you trapped them, they'll quickly be back.
Second, if you release them at a sufficient distance to prevent their return (which is illegal in many states), they'll likely die anyway, because no matter where you put them there will already be mice present, who will viciously defend their territory, and the invaders or the defenders will die. Or the invaders will die of starvation, since they don't know their new territory. To my way of thinking, either of these option seems less humane than drowning.
I'm going to try Mouse-X and RatX first, which are specifically deadly to rodents and which don't poison predators that eat the poisoned rodent.
pdfsendohio 1 year ago
Maniacy 8 years ago
zoressamarias 4 years ago
SheilaY1 8 years ago
JorelH 7 years ago
heavyweather 9 years ago
will that work with rats to? How high do they jump?
MsSweetSatisfaction 9 years ago
I like the options available on this project, also the price point, and clever design. Thanks for sharing!
