Build Your Own Microphone
331,465
69
52
Introduction: Build Your Own Microphone
Ever wanted a microphone to chat on skype or yahoo or aim with your friends but dont wanna buy one well heres your answer to that dilema.
Step 1: Materials
Well the first thing our gonna need is a set of headphones(or earbuds preferably) that you wont want back. You will also need an altoids tin (It can be any type of tin or even a box, i just love altoids tin projects), A pair of scissors or a razor, paper or some kind of tube the headphone jack(part that fits into mp3/cd player or comp) can fit through easily i used paper. Thats about all you need.
Step 2: Figure Out Which Earbud Will Be the Microphone
Ok for this step plug the jack into its place(pink audio slot). After that click Start>Programs>Accessories>Entertainment>Sound Recorder. It will open up a box, when holding one of the headphones up to your mouth click the red circle and say something like "Test Test, This is a Test" now press the square to stop recording and then press the forward arrow to play. If you hear your recording then the headphone you tried first is the microphone is not click File>New when it asks to save click no and test with the other earbud, keep track of which is which otherwise you will mess up ruin your microphone and waste a set of perfectly good headphones.
Step 3: Cut Away the Pointless Bud
Well you could have a useless bud there but i found it to be annoying so with your scissors or other sharp object as close to the jack as possible cut away the second bud
BE VERY CAREFUL AT THIS STAGE, ACCIDENTLY CUT THE WRONG BUD OFF AND YOU HAVE TO START ALL OVER WITH A DIFFERENT SET OF HEADPHONES!!!
Step 4: Paper (or Tube)
Fold a sheet of paper in half, tape the cable in it, then roll up the sheet of paper. If you think it is too bulky then cut the paper in half or so that way theres less material making it bulky.
With a tube just slide the jack down and glue the bud in place so it doesnt slide when pulled
Step 5: The Altoids Tin
now use your scissors, sharp object, or my favorite power drill, to make the holes which your paper and jack must fit through.
Step 6: Almost Done
Now take the jack and feed it through the hole ontop of the altoids tin and then feed it through the hole in the side as well. Bring the paper(or tube) through the hole then close the tin plug in your microphone and your ready to go.
Step 7: Done
congrats on finishing and thanks for reading my first intructable< hopefully you enjoyed it and your microphone works great. I'm not sure if its just because I used 2 dollar headphones for this but mine doesn't pick up sound to well, but others do so try using a pair that cost you 10 dollars but one of the buds died(hopefully not the one you need) Enjoy skype and all that stuff me k? :p ttyl
Minisharkx
Be the First to Share
    • Make it Glow Contest
    • First Time Author Contest
    • PCB Challenge
      PCB Challenge
    52 Discussions
    seymoursunshine
    seymoursunshine
    8 months ago
    Yes, it will work, but it will never function as well as a proper microphone. The reason is that the impedance (= ac resistance) isn't matched. A mic has an impedance of about 500 ohms which is the same as the input impedance of the amp or recorder. A headphone will have an impedance of about 10 ohms. For maximum efficiency, the impedances must be matched. Because they aren't matched by a factor of about 50 or so there is a HUGE loss of power = very quiet.
    They are also constructed differently. The coil of a microphone has many windings of very light wire. The coil of a speaker has fewer windings of heavier wire. They can NEVER be used effectively interchangeably.
    Yes, it's a fun experiment, but it can never be a way of getting a decent microphone on the cheap.
    MicahG19
    MicahG19
    10 months ago
    I was inspired by minisharkx and his earbud microphone. I taught my class to make a GPS out of a popcicle stick and a Jos Louis!
    obimaxharry
    obimaxharry
    8 years ago on Step 2
    I can hear myself, but it is really really quiet! Help please!
    TimothyH111
    TimothyH111
    Reply 2 years ago
    Did you use a mic input or mic preamp. A guitar amp works well.
    AnandG8
    AnandG8
    4 years ago
    I will Try it Today Whether it works or not
    Yan-BrJailson
    Yan-BrJailson
    4 years ago
    i made something much better using basically the same idea, i got a microphone from an earphone and put a p2 on it :)
    works perfectly and sound quality is the same as a microphone from a cellphone.
    PankajJ8
    PankajJ8
    5 years ago
    If we have a headphones, why we need a mic.
    please spend some money for headphones with mic.
    Conesco3
    Conesco3
    Reply 5 years ago
    It isn't actually. I don't think the maker made this entirely clear but still you should have spotted it. Your earphones need to support a microphone connection. At the jack of your earphones there will be small lines going round the metal. If your earphones have two then this isn't going to work for you as that means your earphones only support audio output. If it has three then you should be good as the third loop means that there is an audio input connector for the microphone but I would go and do his check using the sound recorder as well to double check.
    mist.form.7
    mist.form.7
    6 years ago on Introduction
    Any speaker can actually act as a microphone but with varying quality because they were designed to use electrical signals to vibrate a "drum" that produces sound. Then it requires a sensitive "drum" to convert sounds into electrical energy and the quality of this depends on the material and manufacturer of the speaker/earbud you are attempting to use.
    Danielac
    Danielac
    I cant understand what bud Im Supposed to do and you should also put what to do with headphones
    Hzavial
    Hzavial
    plzzz give me video of this.because i cant understood.
    TheDIYHacker
    TheDIYHacker
    I tried the Ible but the sound is Waaaaaaay to quiet even on the loudest setting I can barely hear it. I am on a Mac please help
    zrobles
    zrobles
    8 years ago on Step 7
    i did what you did but didn't work you lied
    Maxaxle
    Maxaxle
    9 years ago on Introduction
    Actually a really good idea, but I bet it sounds slightly tinny.
    Kundancool
    Kundancool
    Waste of time its not what I was searching for its like preparing a stand for microphone not building it
    kdrivas
    kdrivas
    gamw tin omonoia kalamaruia reeeeeeeee
    wii552
    wii552
    9 years ago on Step 2
    it will always be the earbud that is labelled left (with an l on it). If the labelling is worn off, then you can do this, but that will save you a bit of time
