Build a Gear Time Quad Gear Frame
Intro: Build a Gear Time Quad Gear Frame
The Gear Time 3D print series was created by GoTime.us as a free-to-download 3D printable product that gave users a modular gear system which they could build, disassemble and rebuild. One of the simplest configurations was the Quad Gear Frame. This configuration involved 4 gears that were held together with 8 frame pieces and an assortment of axles and fittings.
The Quad Gear Frame is a great way to get started with Gear Time products because it offers a low level of difficulty while introducing you to all of the construction concepts used in Gear Time.
For information about Gotime, activities and the buy premade kits, visit GoTime.us
To buy this kit, visit our store
To print it out yourself, download files here
To keep informed, follow me on Twitter
STEP 1: Step 1: Download and Print Out All of the Needed Parts
Visit the Thingiverse page for the Gear Time Quad Gear Frame and download the package and print out:
- 4x tgear
- 4x taxle
- 8x tframe
- 8x tbearing
- 8x tcap
If the axles did not print flat, the whole thing may not fit together correctly. Reprint any parts that do not come out correctly
STEP 2: Step 2: Start With the Axles
Take 4 taxles and 4 tcaps and press one cap into the notched end of each taxle. The notches should line up to form a 'T' and fit snuggly (see pictures to make sure that the parts are aligned correctly.)
STEP 3: Step 3: Add Bearings
Take 4 tbearings and slip one onto each taxel and slide them down the taxle until they come to rest against the tcap.
STEP 4: Step 4: Add Some Frame Parts
Take 2 tframes and place 2 taxles into the holes of each tframe so that the tbearings will the hole completely. The notched side of the tframe should be facing away from the tcaps.
STEP 5: Step 5: Complete the First Frame Level
Take 2 more tframes and place them in the taxles so that the 4 tframes from a square. the notched side of the second pair of tframes should be facing towards the other tframes. The notches should lock the tframes into right angel corners.
STEP 6: Step 6: Add the Gears
Take 4 tgears and slide them into the taxles so they come to rest against the tframes. The teeth of the tgear should interlock.
STEP 7: Step 7: Add the Rest of the Bearings
Take the last 4 tbearings and slide them onto the taxles so they come to rest against the tgear.
STEP 8: Step 8: Add the Second Frame Level
Take two more tframes and place them onto the tbearings so that they look like a '=' sign. The notches in the tframes should be facing away from the tgear.
STEP 9: Step 9: Complete the Second Frame Level
Take the last 2 tframes and place them on the taxles so that they form a square (just as in step 5.) The notched side of the second pair of tframes should be facing towards the other tframes. The notches should lock the tframes into right angels.
STEP 10: Step 10: Complete With Final Clips
Take the last 4 tcaps and press one cap into the open notched end of each taxle. The notches should line up to form a 'T' and fit snuggly (see pictures to make sure that the parts are aligned correctly.) These tcaps should hold the entire structure together.
Your Quad Gear Frame should spin freely. If not, check for burs in the parts that could be jamming the works.
2 Comments
MsSweetSatisfaction 9 years ago
Ooo so pretty, and looks like such fun to play with!
GoTimeUS 9 years ago
They make nice hand toys (like zen balls.) More plans are on the way!
