Introduction: Build a Mesmerizing Sand Table : a DIY Arduino Masterpiece!
This is a coffee table that draws in the sand using a single Arduino Uno. It's quite fascinating to watch. The first video is an overview, the second video is the instructions for the build.
- Arduino Uno x 1
- CNC shield V3 x 1
- 17HS4023 Stepper Motor x 2
- TMC2209 Stepper Motor Driver x2
- Limit switches x 2
- GT2-6MM Timing Belt x 3m
- MGN12H Slider rails, 600mm and 550mm
- N52 15mm diameter magnets x 6
- 12V 3A power supply x 1
- 120 grit fine sand enough to cover the surface.
- Stepper motor gears x2
- Gears x 4
- 15mm ball bearing x 1
- RGB LED strip
- 3mm wood sheets for Laser cutting
- 5mm dowels
Step 1: Coffee Table
Get yourself a wooden coffee table and take off the top. Put a 3mm thick backboard attached to the legs of the table to hold the sand on.
Step 2: Make the Rails
- Create another baseboard that will go under the 3mm board this will hold our rails and magnets.I used two rails MGN12H Slider rails, 600mm and 550mm
Step 3: Laser Cut the Parts
Download the cad file and cut the parts from 3mm wood panels, these parts will be used to connect the rails and pulleys together.
Step 4: Assemble the Cut Parts
Use the parts to screw the wood joints to connect the two rails and 5mm dowels to hold the gears. Put the N52 magnets on the main slider rail and connect the timing belt in a H configuration.
Step 5: Connect the Electronics
Connect the CNC Arduino shield board to the Arduino Uno. Connect the motors, sensor and limit switch as shown in the diagram.
Step 6: Upload the Code
Upload the Uno code called sandTable.ino you can also add your designs using sandify.org and use the converter.py code to run in Python to extract the x and y coordinates from the G-code
Step 7: Save Planet Earth!
At Newson's Electronics, we're all about reducing e-waste through repairs, one gadget at a time! If you enjoy my content, consider supporting my youtube channel by exploring my other offerings:
📚 Books by the author:
THE LOST SCROLL - https://amz.run/93Gm
HEART OF STONE - https://amz.run/6kXq
UNLOCK YOUR MIND - https://amz.run/6kXr
OVER THE GREAT WALL - https://amz.run/6kXt
Stay connected with me:
👍 Facebook Page:
/ newsonselectronics
💻 Website: https://sites.google.com/view/newsons...
Thanks for watching and supporting Newson's Electronics – let's dive into the world of tech together! 🔧🚀
