Build a Small Scale Hearth Oven
Intro: Build a Small Scale Hearth Oven
If you like baking crusty pizzas and breads then you need to bake on stone and you need to steam the oven for nice crusty breads. It can be kind of a hassle to use a regular oven what with shuffling the baking stone in and out between uses and pouring hot water into an even hotter preheated cast iron skillet to steam the oven. And during the summer wouldn't it be nice to bake your bread outside the house? So let's make our own dedicated small scale hearth oven!
STEP 1: Materials
Materials list:
- toaster oven
- pizza stone
- about 12 inches of 1/4 inch copper tubing
- about 12 inches 3/8 plastic tubing
- steamer
- lid for steamer
I recommend choosing a toaster oven that is fairly tall so that your nice boules don't rise up and burn on top when they touch the upper heating element. Or to be on the safe side, you may just want to remove the upper element as I did.
Make sure to use an oven thermometer for the first several times so that you know how close the thermostat is. The thermostat on my old thrift store oven is off by about 75 degrees! ;(
- toaster oven
- pizza stone
- steamer
- lid for steamer
STEP 2: Aquire and Cut a Pizza Stone
I found a large round pizza stone at a thrift store and then cut it to fit in the toaster oven using a friend's wet saw.
STEP 3: Steam Mechanism
To create my steam I stopped by my favorite thrift store and picked up a Black & Decker Handy Steamer. It comes with a steaming basket which we aren't using for this project but you might want to keep it around in case you decide to steam some veggies to go with your fresh bread! :)
While you're at the thrift store look through the mismatched lids and find one that will fit fairly tight either inside or on top of the steamer base. I got lucky and found a stainless steel lid with a built in steam release valve. Upon removing the valve I discovered that the hole the valve fit into was exactly 3/8 inch and my vinyl tubing fit perfectly! :) A plastic lid would work fine too. If your lid doesn't come with a hole like mine you may need to drill a hole and buy the appropriate hose connector. You may also need to improvise a bit to get a good seal. I used some vinyl finishing trim I had on hand to get my lid to fit tightly.
STEP 4: Fire It Up!
Okay, you should now be ready to put the pieces together and bake some bread! A good test for the oven is to see if you can make a crusty baguette. :) First preheat the oven. Once the oven and baking stone are fully preheated, start up the steamer and get it cranking at full force but don't connect the tube to the oven pipe yet. When all is in order use a peel to slide your risen dough directly onto the stone, then close the door and connect your steam tube. Oven spring mostly occurs during the first ten minutes so after that you can disconnect the steamer and continue baking.
NOTE: Keep an eye on your wattage to avoid tripping circuit breakers or blowing fuses. My toaster oven is rated at 1500 watts but I took out one element so it actually only draws about 750W. The steamer pulls 650W. So that makes a total of 1400 watts / 120 volts = 11.7 amps which means I can safely use a 15 amp circuit. If your particular setup keeps tripping a breaker you may have to run a heavy duty extension cord from a different circuit in your house to power one of the two appliances.
STEP 5: Add a Water Pipe
Cut a short length of 1/4 inch copper pipe. The length should reach from about an inch above the oven down to about an inch above the floor of the oven. My pipe came out about 9 inches long. Now drill a 1/4 inch hole through the top of your oven. (I pre-drilled my hole using a smaller bit first to make penetration with the big 1/4 inch bit a lot easier.) The pipe should fit nice and tight. If you need to caulk around the pipe make sure to use high heat caulk.
12 Comments
Ronyon 12 years ago
Not really an issue, just a visceral reaction.
Very inspirational, could it be applied to a full size oven?
I also love the idea of adding something to the outside of the oven for insulation.
godbacon 12 years ago
Do you think electricity grows on trees?
I like your use of Thrift store Items. keep it out of the landfill and make it work for a living.
but I would caution you on your use of VINAL, especially with steam. VINAL is not food grade and leaches Hormone disruptors into water. Thats why waste lines are PVC and not supply lines. (note: exception, CPVC). The V in PVC: VINAL.
Hope I've been Helpful and "Nice" (note: there is a "be nice" policy. if your not nice you will be tortured till you become so.)
dbell 13 years ago
What hearth temps can you reach?
Dave
SteveGerber 13 years ago
lucek 15 years ago
patrick6611447 15 years ago
Big Ugly Mich 15 years ago
Calorie 15 years ago
whytwulf35 15 years ago
SteveGerber 15 years ago
mbudde 15 years ago
Lftndbt 15 years ago
