Introduction: Build an Arbor for Your Wife.
Start with a plan, either one purchased or a design of your own. Gather your materials and tools needed according to your plan. These will vary depending on your design.
Our arbor is being constructed with pressure treated wood. 4 2x2" for the legs, one 1x4" to make the top portion, and a 4x8' trellis plus a 2x8' trellis to fill in and give our vines something to grab ahold of. To attach it to the ground, I decided to use metal rebar. We purchased all of this material from our local big box store for less than $60.
Tolls that I used include the following, but can vary depending on your methods:
miter saw
circular saw
tape measure
pencil
Brad nailer/stapler
wood glue
drill with 3/8 paddle bit
woodworking clamps
hammer
level
Now is the time to lay out your materials and start cutting them to size.
miter saw
circular saw
tape measure
pencil
Brad nailer/stapler
wood glue
woodworking clamps
hammer
level
Step 1: Assembly
Our arbor is 2' x 4' and stands about 6 1/2' tall. Once your materials are cut to size, you can start assembly. I began by making a rectangular box 2' x 4'. For fasteners I used an 18 gauge pneumatic stapler and wood glue. You could also use screws or nails.
Then I added the trellis to the top of the box cutting it to fit and stapling it in place.
Next I turned the box on one side and attached the legs into each corner using glue and staples, rotating the box as necessary to fasten each leg.
Then for stability, I used the offcuts from the legs to install corner bracing to prevent leaning.
Then it was time to put the trellis on each side. I utilized a clamp to hold the trellis in place while I stapled it onto each leg.
Step 2: Finishing Up
I used the remainder of the 1x4 to provide support so I could add a small hook on each side to hang lantern lights from. You can customize your arbor however you like. We decided not to paint ours and just let it weather.
To anchor it to the ground, I drilled a 3/8" hole into the bottom of each leg. Then I hammered a 2' piece of 3/8" rebar into each leg.
My wife already had vines growing where she wanted to place this arbor. Vines are an option but not necessary. We were able to place the arbor where we wanted it then hammer the top of the arbor to get the rebar solid in the ground. Then I used a level to insure the arbor was plumb and level.
So now you can just sit back and enjoy your handiwork and a happy wife.
