Build an Infrasonic Subwoofer
Intro: Build an Infrasonic Subwoofer
Infrasound is sound that is below your hearing threshold which general drops off at 20-30hz, i.e. lower than big booty bass. It can have a profound effect on your body, and should be experimented with carefully! Infrasound is used by the military as a weapon, or science to monitor earthquakes, whales ect.. In this instructable we will walk you through the process of building your own Infrasonic Subwoofer.
from wikipedia:
Infrasound is sound that is lower in frequency than 20 Hz (Hertz) or cycles per second, the "normal" limit of human hearing. Hearing becomes gradually less sensitive as frequency decreases, so for humans to perceive infrasound, the sound pressure must be sufficiently high. The ear is the primary organ for sensing infrasound, but at higher levels it is possible to feel infrasound vibrations in various parts of the body.
The study of such sound waves is sometimes referred to as infrasonics, covering sounds beneath 20 Hz down to 0.001 Hz. This frequency range is utilized for monitoring earthquakes, charting rock and petroleum formations below the earth, and also in ballistocardiography and seismocardiography to study the mechanics of the heart. Infrasound is characterized by an ability to cover long distances and get around obstacles with little dissipation.
STEP 1: Speaker Cones
What is Qes?
http://www.bcae1.com/spboxad2.htm
http://en.wikipedia.org/wiki/Q_factor
STEP 2: Step Two
Select a wood type. We chose 18mm plywood. This is probably the best material. Avoid Chinese plywood if possible because it is not as consistant. Plywood is very sturdy and holds up well the air pressure produced by the large speaker cones. You need enough wood to make both the box and the bracing structure. Each wall should be braced to handle all the bass. You should try to make the box as big as you can. We built ours to be 30" x 30" x 70" It should NOT be square. This will greatly reduce its ability to produce infrasonic frequencies low enough.
STEP 3: Bigger the Case
We used a combination of wood glue, and as few screws as possible. The box should be airtight so each screw increases the possibility of air leaks and rattling. Then we used Kwik Seal to seal all of the corners and potential air leaks.
STEP 4: Installation
STEP 5: Electronics + Test, Test, Test
You will want to find powerful amplifiers. We chose two livesound amplifiers. Each channel was 500watt amplifier and switch to serial mode to which collectively made one amplifier a mono 1000 watt amplifier.
Once the cone works, then solder together the thick gauge audio cable, connect it from the speaker to a 2 channel Speakon wall-mount connector which we will insert into the wall of the speaker. This will enable you to unplug your speaker but also insert it into a larger live sound system. Then solder on male speakon connecters to thick audio cable and then connect this to your amplifier and add the compatible connector for your amplifier. For us, we used balanced 1/4" connectors.
Test all the wiring by running sine tones through the input to make sure all of your connections wokr.
STEP 6: Cabling
Now once you have tested and solder together your cabling install l all the cabling, solder the speakers, cut holes to the exact size of the speakon jacks + corresponding panel. Then test all the wiring by running sine tones through the input again. At this point you may want to add wooden or metal handles to the side of the Subwoofer because its heavy and awkward to lift!! Ours was close to 70lbs.
STEP 7: Seal the Connections
STEP 8: Step 8
STEP 9: Step 9
STEP 10: Rock
Next crank it up but be slow about it to see how you react to the low frequency. A 15hz sine tone is a good start or even better a sliding tone from 60hz down to 10hz and then back up. From this you will be able to tell when your body feels it intensely and also how low the speaker will be able to reproduce a frequency. Enjoy but be careful!!
106 Comments
atpmarcus 7 years ago
i have no background in any of this i have 3 questions:
1. can anybody suggest a generator that can produce 1.05hz for the purpose of producing HGH in the pituitary gland while i sleep
2.can anybody give me some advice via private communication on how to go about making sub audible frequencys
3.is a frequency the same as a sound i.e if i was to use a online tone generator is it the same and if so is simply turing up the volume while it is running make a difference.
I AM NOT A SOUND TECHNICIAN I AM A HEALTH FREAK so dont go judging guys! lol
thanks
JoesphanL 6 years ago
Just don't. 1.05hz (seems like you need accuracy) will be very hard to generate, not to mention accurately. You would need a speaker the size of your house. The lower the frequency the lower the energy, therefore the more power you would need. The most effective way to generate 1.05hz is to set up a robot punching you every 1 second (I'm not joking - 1 hz = 1 wave cycle per second).
MardyMcFly 2 years ago
guzziebrad 3 years ago
rfoster4 12 years ago
rallen71366 12 years ago
He also said that they had to wear depends. That assignment was the sh*t. :-)
ttitus 12 years ago
Hiwatt Dr504 8 years ago
Man sorry I just realied I have may hijacked this thread. Im a idiot. Sorry again.
whoiswhere 4 years ago
MarkK23 8 years ago
http://soundworkscollection.com/news/the-biggest-subwoofer-in-the-world
katesisco 7 years ago
I would also like to know if you can build an infrasound detector to monitor hobby drones?
One day I'll have them manufactured.
bradhouser 12 years ago
mgann1 7 years ago
Wow what are these people saying..
They need to be in phase, and it doesn't matter what side the speakers are mounted. Pressure inside the box is a good thing and when he says "no longer compresses air" he isn't just talking about inside the box, this is true for outside the box too. Sound is compressed air, no longer compressing the air is no longer making sound. You want to pressurize the room. That's probably why it effects your body too.
If you wanted to put them out of phase you would have to separate the two chambers so that each speaker can pressurize when it needs. Phase does change with distance, but the frequencies are so low that they will not be out of phase being on opposite sides of the box, this would only be true for higher frequencies. I'll bet that the designer of this box put the drivers on each side of the box to limit any movement that might occur from these large diaphragms moving, if you put the drivers on the same face the box might get pushed around or vibrate distorting the "silence" of the subsonic frequencies. Honestly I would look into designing this as a ported box instead of sealed to get more decibels out of the low frequencies, that's a post for another day. If you keep it sealed though, larger the box the better the low frequency response but you put the drivers at risk, they're only made to reach 22hz or so. Also would recommend applying resin to the cone as they suggested to lower the resonant frequency.
Unless maybe you guys were thinking of reversing the polarity and playing each driver at a different frequency? You can use the frequency cancellation to your advantage, but you must separate each driver into its own chamber. Build this box with a wall in the middle and reverse the polarity as you thought. Then play each driver at different, but at their rated and loud, frequencies they will cancel out some of the waves but not all leaving you with the difference. Hopefully high decibel low frequency waves will be left. If your resonant frequency with the sealed box is 54hz that means the box will play those frequencies the loudest. So with reversed polarity try playing one speaker at 50hz while the other at 60hz hopefully giving you a 10hz overall sound. Actual results might vary, try different tones.
What would happen if you attached that 10Hz to a carrier frequency...
Offroadie 12 years ago
keriksen1 12 years ago
Not being a sound engineer, my understanding is limited. So I welcome clarification based on sound (pun intended) principles.
This is what I think is happening.
In a normal stereo setting, when the woofers are out of phase they tend to cancel each other, an effect that is increased with lower frequencies.
However, this scenario is different. For one, they are not in separate boxes, and they are pointing in opposite directions. Add the fact that the box is sealed, keeping them in phase causes both cones to move in and out together. This increases and decreases the pressure of the air in the box. Being sealed with no port to the outside, this would tend to dampen the sound, making it quieter.
If the two speakers are anti-phase, one moves in while the other moves out, keeping the pressure on the internal air the same. Wouldn't that tend to boost the volume instead of reducing it?
