Building a 24' X 20' Deck on Steep Slope
Intro: Building a 24' X 20' Deck on Steep Slope
TOOLS: SHOVEL, WHEEL BARREL, STRING, PLUMBBOB, SQUARE, 5 GAL BUCKET, HAMMER SCREW GUN, MITER SAW, DRILL PRESS, I USED A NAIL GUN, LOTS OF STAKES, SKILL SAW, SAWS ALL, DRILL, PAINT BRUSH, 2 WRENCHES, LEVEL, WATER LEVEL IS BEST, STRING LEVEL, ,, so this instructable will cost you around $15,000 if you have to purchase all materials, I'll try to get all materials right here, with approx. footage.. concrete 200 90lb bags, sonotube, 3 - 6x12x24 girders ( beams) 3 - 4x6x16 posts , 12 - 4x4x8 posts, 32 - 2x12x16 joists, redwood decking, 48 3/4" nuts,98 washers, 4 - 8' sticks of all thread , 24- 10' sticks of galvanized pipe 1/2", pressure treating adhesive 4 cans, steel plates for post to girder connections, simpson concrete ties for footings, 50lb box 3in. gal. hot dip nails, box of deck screws, couple cans spray paint,
STEP 1: Getting Started
ok it took me by my self nearly two days to lay out and square up the strings to mark my footings. Once you get it all square dig the furthest corners first, set the sonotube hanging in the hole up off the bottom of the ground about 1 ft. so the concrete sluffs out as a footing then before it sets up push your simpson tie into concrete, level it make sure its still square with the rest. then hang the girder from corner to corner then you can hang a string down from girder to mark the rest of your footings exactly.
STEP 2: Joist's and Paint
Ok the three girders are set and bolted down , now paint all of the joist's with a green wood preserver, if you want it to last. now lay out your joist's start from one end and block each joist on all three girders as you go nailing everything, this should be the fastes part , the most rewarding,
STEP 3: Post Rails
then cut your railing post so it reaches the bottom of your girders and block it in from the edge and through bolt them lay out is 8' or what ever your choice. after all the railing posts are in and tight start the decking from the furthest spot (highest spot)
STEP 4: Railing
now the railing tricky must be no more than 4" apart take some of your red wood boards up on edge and mark every 4" two at a time make them exact drill press your holes not all the way through the board though and cut the 1/2 " galvanized pipe into 32" pieces (think that's the number) and paint them. youll be able to figure the length by the height you want your railing.
STEP 5: Then Stain It and You Should Be Good.
before and after thanks for looking
8 Comments
nickton 4 years ago
Nice deck though. It should last a long time.
PatA52 5 years ago
How did you tie into the slab? aren't you worried about moisture getting in between? How did you plan for that?
ImusIndustries 6 years ago
Beautiful deck. On a hillside or slope deck like this I would recommend Imus Cap for joist and beam protection against wood rot. Very easy to install.
bgarrett 10 years ago
damienrv 10 years ago
I wanted more deck space. the posts have 4 through bolts in both directions they are sound.
Iron Cowbell 10 years ago
vincent7520 10 years ago
