Introduction: Building a 3D Printer Under 299$
Hello again, remember me?
I have published an instructable about how to make a 3d printer under 200$ - Tower Simple XL.
It's a low cost, full-featured 3D Printer, and the most important thing is, you don't need any 3Dprinted parts to build the 3D Printer. If I have a 3D printer,I don't have to look around how to build a 3D Printer...
If you are interested in creating a 3D Printer, you should have seen it. https://www.instructables.com/id/Building-a-3D-Prin...
And today I brought another more excellent project. Introduce my new machine - Vaster Mini3.
Salute to i3.
## Update v1.2.1 on step 23 ##
2015-09-22
Fan duct .stl file for Mini3 published on thingiverse: http://www.thingiverse.com/thing:1026997
Screws and bolts list added.
Fine-tune.
Step 1: Mini3 Version 1.0
This is the original version of Mini3 , I define it as the Version 1.0
I've done a lot of work to upgrade it, the latest Version of Mini3 is 1.2.1 , at 2015-09-22. and I'll show it in the following instructable.
In fact, all the versions are very similar.
What is highlighted in picture 2?
Check this out and find something interesting, http://www.thingiverse.com/thing:5762
Don't waste any materials.
Step 2: Lasercut
Wood thickness 5 mm to 5.2 mm.
Step 3: Assemble the Main Body
Pay attention to the position of the board.
Version1.1 is the same principle.
Step 4: X Axis
Assemble the X axis.
## X-axis part list ##
Synchronizing wheel ; 2GT-20T ; 1
Synchronizing belt ; 2GT belt ; 600mm
Optic axis X- 225mm- Diameter 8mm ; 2
SK08 ; 4
SC8VUU ; 4
SC8UU ; 3
F625 ; 2
Leadscrew nut- T8 ; 2
NEMA17 ; 1
End Stop ; 1
Just push-fits SK08/ SCS8VUU/ SCS8UU/ F625/ NEMA17 together.
Step 5: Y Axis
Assemble the Y axis.
## Y-axis part list ##
Synchronizing belt ; 2GT belt ; 500mm
Optic axis Y- 245mm- Diameter 8mm ; 2
SK08 ; 4
SC8UU ; 4
F625 ; 2
5mm-8mm Coupling ; 2
NEMA17 ; 3
End Stop ; 1
Just push-fits SK08/ SCS8UU/ F625/ NEMA17 and Coupling together.
Step 6: Assemble!
Attach X axis to main body with.
## Z-axis part list ##
Optic axis Z- 318mm- Diameter 8mm ; 2
Leadscrew - T8 -300mm ; 2
End Stop ; 1
No zip tie, get stronger.
And now we have successfully assembled a Mini3 V1.0
Mini3 was inspired by my desktop CNC.
I used to think of transforming the CNC to 3D Printer, But its printing speed is too slow. I think if we want to use the CNC to 3D Print, it must use ball bearings instead of leadscrew.
Step 7: Mini3 V1.0
Step 8: Mini3 V1.0
Step 9: Mini3 V1.1 , a New Beginning
After assembled Mini3 V1.0, I found its potential for upgrading and created an upgraded version.
In fact, V1.1 and V1.0 are exactly the same. Except a full version of the shell and some of the details of the adjustment.
Step 10: Mini3 Version 1.1
The latest Version of Mini3 is 1.2.1
2015-09-22
Step 11: Lasercut
Lasercut as usual.
Step 12: Assemble the Main Body
Step 13: Mini3 V1.1
Step 14: Electronic Parts
In this 3D Printer project, i continuing to use RAMP1.4, So it's the same with Tower Simple XL.
1. LCD 2004 *1
2. Arduino Mega 2560 *1
3. Ramps 1.4 *1
4. A4988 StepStick Stepper Motor Driver *4
5. 12V 40W Heating pipe *1
6. NTC Thermistor 100k
Step 15: Mini3 V1.2 , Instructables Edition
Mini3 V1.2 , instructables edition
## Update ##
Add 2004 LCD smart controler.
Add Mini3 extruder mount.
Fine tuning.
Step 16: Mini3 Version 1.2
2015-09-22.
Step 17: Lasercut
Lasercut as V1.0 and V1.1.
Step 18: Assemble
Assemble the main body
Remove parts from V1.1 to Version 1.2
Step 19: Mini3 V1.2
Step 20: Mini3 V1.2 Extruder Mount
I designed new lasercut parts to replace the old one.
Not only more firmly, but also cheaper and easy to get.
Step 21: Finished!
Finished and run some tests.
Step 22: Vaster Mini3
Step 23: Mini3 Version 1.2.1
Mini3 V1.2.1 , Ultimate upgrade for 1.2 series.
## Update ##
Add Mini3 fan duct.
New control board.
Fine-tune.
Step 24: List of Screws and Bolts
## part list ##
All the number of screws and nuts.
M3*10 screws / stainless steel / 35
M3*12 screws / stainless steel / 3
M3*16 screws / stainless steel / 48
M3*27 screws / stainless steel / 2
M3*30 screws / stainless steel / 6
M3*35 screws / stainless steel / 2
M3*40 screws / stainless steel / 9
M3*6 screws / stainless steel / 15
M3*8 hexagon copper post / brass / 14
M3 spring washer / iron / 35
M3 gasket;washer / iron / 63
M3 nuts / iron / 61
M3 thumb nut / iron / 4
M4*10 screws / stainless steel / 1
M4*12 screws / stainless steel / 14
M4*20 screws / stainless steel / 9
M4 spring washer / iron / 14
M4 gasket;washer / iron / 14
M4 nuts / stainless steel / 2
M5*30 screws / stainless steel / 2
M5 spring washer / stainless steel / 4
M5 gasket;washer / stainless steel / 4
M5 nuts / stainless steel / 2
M6*12 screws / stainless steel / 16
M6 gasket;washer / stainless steel / 2
M6 nuts / stainless steel / 2
Step 25: Mini3 Part Display 1
1.SC8UU
2.SK08
3.SC8VUU
Step 26: Mini3 Part Display 2
1.NEMA17 ; MK8 Extruder and i use 1.75 filament.
2.T8 lead screw ; 300mm*2.
3.Axis diameter 8mm ; 318mm*2 / 245mm*2 / 225mm*2.
Step 27: Mini3 Part Display 3
1.2004 LCD smart controller ; 4G SD card
2.Ramps endstop
3.All-in-one MKS board
i use all-in-one MKS board instead of original Ramps control board, in fact they are the same. MKS board is based on Ramps and it just make wiring more convenient.
Step 28: Mini3 V1.2.1
Step 29: Mini3 V1.2.1
Step 30: Mini3 V1.2.1
Step 31: Cube Test
slice by cura 0.2 layer height and 10% infill ; print with raft.
Step 32: Cube Test
Step 33: THANK YOU FOR YOUR SUPPORT
This is about how to build a high-performance 3D Printer under 299$.
Thanks for taking the time to check out my instructable on how to build a 3Dprinter, if you like this instructable, please vote for me on EPILOG CONTEST VII, If i won the laser system prize, i will offer free laser cut service of Mini3 lasercut files for any one who want to build Mini3 and vote for me on EPILOG CONTEST VII, please vote and come back leave a comment. (just free laser cut service, not free material and free worldwide shipping)
Feel free to comment and share this project with your friends who might like this instructable. Thank you for your support.
![Epilog Contest VII](https://content.instructables.com/FAY/0RZL/IDQBK84H/FAY0RZLIDQBK84H.jpg?auto=webp&frame=1&width=320)
Runner Up in the
Epilog Contest VII
