Building a Shower Pan With Vinyl Liner
Intro: Building a Shower Pan With Vinyl Liner
STEP 1: Build the Walls and Expose the Drain
The shower walls have been framed like any other wall with 2"x 4" studs, generally 16" on-center, and pressure-treated sill plates (the lumber that sits on the floor). During the "rough plumbing" of the shower and tub, the drain pipe ends were each encased in plastic boxes, so when the slab was poured a void was created surrounding the end of each drain pipe. This photo shows the shower walls built (with design features like a space at the tops of walls and glass block "windows"). The drain boxes are also visible, with one inside the shower walls and the other for the future tub drain. The boxes will be cut away to expose the drain pipes inside.
STEP 2: Build a Shower Curb
STEP 3: Construct a Trap and Place the Drain
STEP 4: Fill the Void
STEP 5: Block the Lower Shower Wall
STEP 6: Trowel a Pre-slope
STEP 7: Finish the Pre-slope
STEP 8: Install the Vinyl Sheet
STEP 9: Install Mortar Forms
STEP 10: Troweling the Pan
STEP 11: Final Pan Mortar
STEP 12:
Once the form boards are removed a nice clean edge is left for mounting the tile backer board. Cardboard is put on the floor to protect it for the rest of the job. If you like this instructable, I have a book on Amazon called, "Owner-Builder: How an Amateur Built a Professional-Grade Home Addition" by Bill Mathews. Check it out, and thanks for looking.
9 Comments
Icelandian 2 years ago
Tuffys Dad 2 years ago
Thanks again. (depending on how it turns out I may do an instructable on it too.)
Sorry one more question - Do you continue the slope on the outer walls or do you draw a straight line between each pair of corners. Image attached below is a 3D model of my preslope with a uniform slope from the drain. The blue line would be that straight line mentioned.
Hamlin57 8 years ago
I am doing a complete remodel of a 950 sq. cottage with walkout basement, again THANKS.
Penolopy Bulnick 10 years ago
That is impressive! Nicely done!
Tuffys Dad 10 years ago
