Introduction: Building a Solid State Tesla Coil
!This instructable is meant to give detailed instructions on building a solid state tesla coil based off of steve ward's mini sstc schematic.
Ok, here's the disclaimer.
I do not hold any responsibility or your use or misuse of this information, in any way. I am not a trained professional and I cannot protect you from the voltages that are part of this project, and any damage this project may cause, wether it be to animal or material. The user assumes all responsibility for the actions they take.
Well, now that that's over, lets get on to what a tesla coil actually is.
A tesla coil usually has these key components:
*power source
*Switching circuit
*Resonant Capacitor (only for drsstcs, some vttc,s and regular spark gap type coils)
*Primary coil
*Secondary coil
The tesla coil was invented around 1891 by Nikola Tesla. His original intention for the device was to create a wireless energy distribution system. Unfortunately, his design could not send power at even close to reasonable efficiency, as the power was almost all being wasted on corona and arcing. Today, we coilers take this to an advantage.
But what males the tesla coil truly magnificent is the voltage it produces. A typical spark gap type coil takes (usually) the voltage from your wall socket, and steps it up to a couple thousand volts, where it then goes through the switching circuit, through the primary, and is seen on the secondary side as more that 200,000 volts! But how did tesla do this?
The answer is resonance. A resonant circuit, usually consisting of a capacitor and inductor, is much like a slinky. (stretched out) When you give it a push, it bounces back and forth losing momentum with each pass. However, if you keep hitting it every time it comes back, it will start to move really far back and forth at the same speed. (Or frequency) The frequency at which you hit it is it's resonance.
The secondary coil is like our spring. But how do we get voltage from it? Certainly not by hitting it. No, you have to use an oscillating magnetic field from the primary coil to excite it. A normal spark gap type TC would use a resonant capacitor and a spark gap to produce the oscillation, where as our coil (sstc) will use feedback from the coil itself to drive the primary. (using an antenna.)
~~for more info on how a tesla coil works, head on over to Richie Burnett's site or the wiki.
Step 1: The Overview
Our coil will be a solid state type. The schematic we are using was made by steve ward, and belongs to him. This circuit is a relatively simple circuit as far as tesla coils go, and is a good place to start for a coiler that is new to solid state drive. I will say that you should only attempt this if you are confidant that you can work with mains voltage, as this coil does have direct mains voltage running through part of it.
Unfortunately, I cannot currently put up the steps to wind the secondary coil, but I will put up an intractable as soon as possible. But generally, what you need to do is wind many tight turns of thin magnet wire around a pvc form. Don't make it too tall. A good ratio for height is that the height is about 3 to 5 times the diameter.
Anyway, what you will get out of this coil is approximately 7-8 inch sparks. (Depending on how you set the interrupter) I'll go over this later, but for now, that is what you can expect. Trust me, you'll have fun.
*****EDIT: That mystery symbol appears because instructables cant handle the µ and Ω symbol in pictures. go figure! it works here.
Step 2: Equipment
A tesla coil is a very interesting, and fairly complicated device. Aside from building this coil, There is some special equipment I highly recommend using if you power this little beast up. There are dangers involved in a mains-powered-hundred-thousand-volt-producing machine, as it turns out. :D
We wil be doing a lot of soldering for this coil. And I mean a lot of soldering. I used up about five feet of solder at least! So, with that considered, our first items are a soldering iron and a desoldering iron/desoldering pump/soldering wick of some sort, that is, unless you can solder perfectly. Now, unless you have a fancy super durable soldering iron, It is likely that you will be using a radioshack iron. It has been my experience that the tips on these things, even with the most obsessive cleaning, these tips just get eaten away. So, buy an extra tip. ;) You will also want some flush lead clippers to trim down component leads. In case you don't have a store near you, here are some links:
Soldering iron
Desoldering iron
Extra tip
Lead clippers
Now, As I said before, there is more to the coil than building it. When we test it, we should not just go and jam the plug into the wall socket. The equipment I say you must have before you power this thing up is a variac, or switch of some sort two protect yourself from full mains. What a variac is is basically a variable transformer. It allows you to alter the voltage that flows from the wall socket to your device, much like a gigantic kilowatt volume dial. You can find a good variac for around 80 dollars at a local electronics store, assuming they haven't completely turned ti consumer electronics, but I'd recumbent getting one online from say, Fry's electronics. They have two models. A low power one and a high power one. The low power on was enough for me to use on this project.
Low power variac
High power variac
While this Is all the equipment I would require myself, It is nice to have an oscilloscope for measuring gate drive waveforms and looking at interrupter input. It is also nice to have a variable DC power supply for testing the low voltage electronics, but again, it is not required.
Step 3: Parts in Parts
As you can see from the schematic, there are plenty of parts to this circuit.
So, lets get starter with the
fundamental power components:
25v 2a transformer
bridge rectifier
lm7805
lm7812
50v 2200 µF capacitor (X2)
25v 1000 µF capacitor
5.6kΩ resistor
2.2kΩ resistor
Blue LED (X2)
Now, the Interrupter components:
0.1 µF decoupling capacitor
NE555
10kΩ linear potentiometer (X2)
1n4007 diode (X2)
2.2kΩ resistor
0.1 µF capacitor (This can actually be any value you like, It will simply alter the arc appearance/interrupter speed.)
Next, we move on to the antenna section:
74hc14 hex inverter
6-8 inch long piece of wire
1n60 diode (X2)
0.1 µF capacitor
Now, we move on to the gate drive components:
UCC37322
UCC37321
1 µF decoupling capacitor (X2)
0.1 µF capacitor
2 foot long strand of wire (X3)
Ferrite toroid
Now, for the scary mains filter:
Bridge rectifier
200v 680 µF capacitor
Finally, the muscle of this circuit, the half bride:
IRFP260N mosfet (X2)
200v 0.68 µF capacitor (X 2)
5Ω 2W resistors (X2)
Insulating thermal pads (X2, TO-247 type)**
Heatsink with two matching screws and holes*
Thick non-stranded wire, about five feet
ALMOST FORGOT! don't forget
SOLDER
These are the necessary components. I used digi-key because they are easy to use.
*I got my heatsink from an old atx power supply. There are full of useful stuff!
**Usually also found in tax power supplies.
I also recommend getting some terminal connectors. They make everything so much easier.
Terminal connectors
Step 4: The Voltage Supply
So, the first part of the circuit I chose to solder was the voltage supply. This was primarily because it is connected to every other part of the circuit. Anyway, I first soldered in the terminal for connecting the transformer in, right next to it, the low voltage bridge rectifier. Luckily, they match up!
*A tip for soldering long or high current connections: Lay down a piece of metal wire to the path you want to solder. It makes it much easier to apply.
PARTS:
25v 2a transformer
Bridge rectifier
LM7805
LM7812
5.6kΩ resistor
2.2kΩ resistor
Blue LED (X2)
Step 5: The Interupter
Next, we move to the interrupter. This is the part that turns the coil on and off. (we need to limit the onetime so that we don't completely wear out those mosfets. The reason we have chosen to make this part before the rest (After the power supply) is so that we can test it before finalizing any connection to turn on the coil.
PARTS:
NE555
1n4007 diode (X2)
2.2kΩ resistor
Step 6: Antenna Section
Now, we will put together our antenna section. This part of the circuit is designed to capture feedback from the secondary to keep the circuit resonating. Because we use feedback to provide the signal to our halfbridge, the coil is always in tune! No worrying if you have that pesky 555 on the right frequency.
74HC14 hex inverter
1N4148 diode
0.1 µF capacitor
Step 7: Gate Drive Section
In this step, we will assemble the part of the circuit that combines and amplifies the interrupter and feedback signals to drive the gate drive transformer. These parts can fail more than others, so it's not a bad idea to instal sockets.
UCC37322
UCC37321
0.47 µF capacitor
Step 8: Gate Drive Transformer
The gate drive transformer does exactly what it's name implies. It takes the signal from the UCC's and sends it to the mosfets, as well as isolating the low voltage side from the high voltage side. To make the transformer, first, take your three pieces of wire, and twist them together. This creates a trifler winding. Next, wind the wire around the ferrite toroid 16 times. (Each time the wire passes through the center is one turn) after that, cut the wire so there is about 2 inches on each side of the transformer. Now, take two ends of wire of the same color, and solder each to one output of the gate drive section.
Ferrite toroid
Step 9: Mounting Mosfets to Heatsink
Now, when you switch 120 volts at hundreds of thousands of times per second, It is almost indefinite that you will generate some heat. We use a heatsink to channel that heat away from the mosfets, and into the air. To mount them is simple, but DO NOT FORGET YOUR THERMAL PADS. they keep the mosfet drains from shorting out.
PARTS:
Mosfets
Thermal pads
Heatsink and matching screws
Step 10: The Half Bridge.
Here is the muscle of this coil, the half bridge. what this is are two mosfets that alternate switching on and off to produce alternating current. They do this at a high voltage, mainly so we can pump power trough the primary. this causes a magnetic field to be formed that excites the secondary coil (resonator) and the resonant rise builds up the high voltage. Once it is high enough, it breaks out into air.
PARTS:
IRFP260N mosfet (X2) mounted to heatsink
5Ω 2W resistors
Step 11: Primary Coil
The primary coil is where all of that work pays off. The signals are amplified and pushed through here to make the secondary make sparks. To make the primary, first, find a circular object about the diameter of your primary, and wrap your thick wire around it five times, leaving ~6 inches on each end. then, using a twist tie, or you hands (If you don't have an easy method of securing it) Hold it together. Get your secondary coil, and put the primary around the base of the secondary. ****As there will be high voltages present on the secondary, (Hopefully) put some kind of insulator between your primary coil and secondary coil if at all possible. However, if you don't have any, just keep the primary as close as possible to the bottom, possibly using hot glue.**** Once that is done, we can move on to our first test!
Step 12: Setup/test! Yay!!!!
Now, we're ready to set up for the test of our coil, or the "first light!"
1. Attach your transformer of variable dc power supply to the low voltage in, and set to above 15 volts.
2. Attach the two leads of the primary coil to your output terminal near the bridge
3. Grab an ac cord that you wont ever want and strip it open, putting the hot and neutral wires into the AC in terminal.
4. Connect the bottom wire of your secondary to the mains ground, if you do not happen to have a better earth growing connection.
5. Plug in your variac and DC power supply and set the variac to zero volts, turned off.
6. Turn on your DC power supply
7. Plug the ac cord into your variac.
8. Turn on the variac
9. cross your fingers and slowly turn up the voltage. If you did it correctly, you should see arcs coming out of the breakout point!
Good luck! And thank you for reading my first Instructable.
Finalist in the
Epilog Challenge
267 Comments
3 years ago
How to do the antenna part? Is it just a wire inside the secondary tube?
Reply 2 years ago
It is a 6-8" long copper wire sticking straight up and out of the PCB near the tesla coil.
Steve Wards original design: https://www.stevehv.4hv.org/SSTC5.htm
10 years ago on Introduction
and isn't it possible to play music with this? if so how do i do it?
Reply 2 years ago
I know there is no way this commenter still pays attention to this thread but others may find the answer helpful.
To play music you need to use the amplitude of the sound to select the duty cycle of the interrupter. I usually see people using an arduino and a SD card shield to do this easily. The frequency of the PWM should be above audible frequencies. Now the average power of the tesla coil will change with the amplitude of the audio signal. Because of the expansion of the heated gas near the arc the pressure of the expansion will be proportional to the power, which is proportional to the music, that is what we will hear. If you do not choose a carrier frequency higher than the range of human hearing (30kHz+ is good) you will be able to hear it as a high frequency tone.
edit: Keep the PWM frequency as small of a fraction of the resonant frequency of your tesla coil as possible or it may severely limit the output power.
Yes it is. I used this circuit I found for audio. http://wiki.xtronics.com/index.php/File:555c.png
Question 4 years ago
Can i power this by mains 230VAC@50hz if i modify it? i would add much more turns and get some really beefy mosfets, maybe igbts, that would handle the rectified 320VDC.
Answer 2 years ago
I know it's been a while but people may still be wondering.
Double the windings of the primary, use properly rated filter caps on the mains filter (400V - 500V) as well as the 0.68uF polypropylene caps and you'll definitely want to beef up the transistors. I recommend using the same IGBTs One Tesla used (FGA60N65SMD) since it is a very similar design to this one. You'll also probably want some Transient Voltage Suppression diodes like this one (1.5KE510CA). I already had problems with the IRFP260 being destroyed at 120VAC and the TVS diodes should help.
You can also increase the voltage to 320V on the primary if you are using 120VAC if you connect two capacitors in series and use the midpoint as your ground reference. Then you will have +170V and -170V. if you increase the number of primary windings this will lower the current flowing through your transistors, which will decrease resistive losses.
See the One Tesla schematic for more details: http://onetesla.com//media/wysiwyg/downloads/tsschem.png
5 years ago
whats the difference between UCC37322 and UCC37321
Reply 4 years ago
one of them is inverting and the other one is non-inverting. in half bridge, one transistor MUST be turned off while the second one is turned on. you need to use this setup, otherwise it would short the circuit, melt the wires and maybe explode.
Question 5 years ago
Hello there!
That's such a great demonstration of this project, I'm going to totally try it out.
But there is one thing that bothers me, you totally skipped those MUR860 diods on the half bridge. Aren't those neccessary to protect the transistors?
Question 5 years ago on Step 5
What is cap sub point and resistor sub point in the interruptor
6 years ago
what can i use intead of ucc 37322 and ucc37321
Reply 5 years ago
I would reccomend following this instructable: https://www.instructables.com/id/Solid-State-Tesla-Coil/ - its a modified design of this one, that uses different chips.
6 years ago
can anyone pls help its urgetnt the comment below
6 years ago
replace your 0.68uF caps with the resonant caps :) (so you need 2 of them)
i skipped the interrupter and used my signal generator for the interruption.
low duty cycles on low frequencys are fun!
Reply 6 years ago
Are you saying to change that capacitor to a value which would make the primary a resonant circuit at the same frequency as the secondary? Do you have pics of your driver setup?
Reply 6 years ago
This is the current Output Driver im using.
It's a bit overdone on protection diodes.
But seems to work great.
and because i made use of the real tank cap values.
output is significantly higher.
you can tune your primary tank by tuning it with 1 tank cap
when tuned you just put the second one in and poof it works :)
Reply 6 years ago
This mode of operation isnt actually using the primary side caps in resonance. What you may be seeing is closer to zero voltage switching, which can have benifits in allowing more power to be pumped through the fets without thermal damage. In ordet to operate in resonant mode, you would need sognificantly larger caps on the bridge and an actual series resonant capacitor in between the bridge and primary, but be warned, without a proper current monitor circuit, you are likely to blow up your bridge on higher duty cycles and on-times. This is a rather dated instructabel, but there is plenty of better info out there for anyone looking.
Reply 6 years ago
Or change the bridge caps to 2 resonant caps :)
Reply 6 years ago
Thats not a DRSSTC though, as the primary circuit doesnt ring up. In order to actually be resonant, you need to have a single resonant capacitor (or capacitor bank) in line with the primary, not two strattled to the beidge rails. In the scenario youve described, youve just set your bridge capacitors to limit the current to zero during switching. To actually have resonance, you need to move the resonant cap to be in series with the primary, and either construct an H bridge, or replace the bridge caps with sufficiently large bypass capacitors.
