Building a Wifi Booster DIY Style
Intro: Building a Wifi Booster DIY Style
Learn how to boost your wifi signal for next to no cost with this simple DIY guide
Origonal Article: Building a Wifi Booster
STEP 1: Cutout Required Parts
The first step is to cutout the main parts for the reflector. You may download a stencil from this link:
http://www.imod.co.za/wifi.pdf
Once you have downloaded that stencil, simply cut out the two shapes as shown in the image below.
STEP 2: Cover in Tinfoil
Once we have cutout our shapes in step 1, we need to cover the shapes in tinfoil and fold them to the correct positions. The guide in step 1 will show you how to fold them. The image will explain better..
STEP 3: Cutout a Small Hole for Antenna
At this point, we will have two shapes, cutout, covered in tinfoil and folded to the appropriate position. We will need to cut a small hole out for the routers antenna to peak through. See image:
STEP 4: Put It All Together
Simply place your booster onto your current antenna, and that's it.
Enjoy a lovely increase in your signal strength. Remember to aim your booster in a good direction.
Have fun!
Have fun!
19 Comments
zikzak1 9 years ago
Dont put foil on the center brace. it will work much better.. :)
Dia1Up 12 years ago
PhanBoii 13 years ago
marcocera1982 15 years ago
sn00ze 14 years ago
urbanwireless.info/index.php/antennas/parabolic-reflector
heavydeath 15 years ago
dbtk44 15 years ago
PhaZZed 15 years ago
claunek616 15 years ago
Your pdf has a little error the plate is smaller than the part on put the anthenna (i know the design it´s that, but don´t works)
You must be change to this one, to get a best instructable.
https://www.instructables.com/id/DIY-WIFI-Antenna-Reception-Booster/
Thanks at lot to listen.
ShaunHill 15 years ago
TechNetz.com 16 years ago
Body4Change.com 16 years ago
samv 16 years ago
nagutron 16 years ago
jimtran93 16 years ago
PhaZZed 16 years ago
GorillazMiko 16 years ago
!Andrew_Modder! 16 years ago
