Bulbasaur Flower Pot
Intro: Bulbasaur Flower Pot
Make a Bulbasaur (actually more of an Ivysaur) that holds a plant on its back.
Materials needed:
- A small plant in a pot
- Printer
- Thick paper (if available)
- Paper mache
- Utility knife
- Paints
- Aluminium foil & tape
- Spray lacquer
STEP 1: Build the Structure
Download the ivysaur papercraft from pokemonpapercraft.net, which will form the base. It works well, as it has a large, straight-ish back to put the plant in.
Print it out on thicker than normal paper (if available) as that will increase the stability of the design. Make sure your printer can use it. Assemble with glue (and tape, if required).
We used A4 for printing, which resulted in an Ivysaur of 11cm x 10cm.
STEP 2: Cover With Paper Mache
In order to make a structurally sound Pokémon, we'll use paper mache to cover the whole body.
Wait till each layer has dried before applying the next one to prevent the papercraft from getting too soggy.
We applied about 4 layers of newspaper and finished off with a layer of white paper for easier painting. Wait at least a day to allow everything to dry through properly.
STEP 3: Color
Color your Pokémon using opaque colors (we opted for acrylic paint).
We used light blue as a base and mixed in some green.
In retrospect it might have been cleverer to cut the hole for the pot (next step) before coloring, so you might want to consider doing that first.
STEP 4: Cutting a Hole for the Pot
Using a utility knife / X-Acto blade make a hole in the back of the model.
Keep enlarging the hole and testing with the flower pot to get a snug fit.
STEP 5: Add Details
Add some character by painting on details:
Eyes
We printed the papercraft again and cut out the eyes to get an idea of their correct size and position. Then painted first a layer of white acrylic paint, then a layer of red and added the pupils using a marker. Also use the marker to draw a line around the eyes to highlight them and give a neater look.
Spots
We simply used green to paint the spots by freehand. They have 3 or more corners, rounded edges and are usually accompanied by a smaller spot next to them.
Teeth
Cut out and glued together from the papercraft (little pyramids) and glued in place.
Nose, ears, toes, eyebrows
Just painted on with acrylic and marker.
STEP 6: Finishing Touches
In order to make the Pokémon shiny, we'll use spray lacquer (from the hardware store).
Follow the instructions and coat the model with a few layers of lacquer (we did about 4).
In order to stop water flowing into the body (in case of overwatering the plant) we built a flexible coaster out of aluminium foil and tape and put it inside the body. It needs to be flexible in order to fit through the hole while being larger than the base of the flower pot.
We added some stones in the front to offset the weight of the plant and keep Ivysaur from tipping over.
You are done! Enjoy your shiny Pokémon flower pot.
EDIT:
It seems this instructable has garnered a bit of attention. Here are some articles written on the subject, containing other cool ideas:
- SMOSH | 10 Geeky DIY Crafts You Should Totally Try
- io9 | We Want To Catch All These Pokemon-Shaped Flower Pots
- Sprite Stitch | Pokemon Flowerpots
- Nerd Approved | Cute And Colorful Pokémon Flower Pots [DIY]
- BluGadgets | Coole Pokémon-Blumentöpfe zum selber basteln
EDIT2:
I love the different derivations and improvements that were made to this design. Check out the following projects:
- cute ivysaur flower pot | Deviantart, by 95n
- Bulbasaur planter | instructable by misko13
- 3D-printed Bulbasaur Succulent Planter w/ free file | instructable by mstyle183
- 3D Printed Bulbasaur Planter | instructable by GrandeSwag
18 Comments
Battleant121 8 years ago
chrisma0 8 years ago
Thanks! :)
Do post pictures if you decide to try it yourself!
kreator 10 years ago
euphemism 10 years ago
Same.
https://www.instructables.com/id/Oddish-Flower-Pot/
wait.
chrisma0 10 years ago
Make ALL the Pokémon :)
magicman391 10 years ago
would it be possible to attach a pdf of the unfolded papercraft?
Hi. Do you mean the papercraft template? I used the one by pokemonpapercraft.net, which can be found here (also linked in step 1). You can download it in A4 or letter format.
JonnyBGood 10 years ago
Thanks! I totally want to see someone build a larger version (i.e. using A3 paper for the papercraft) as well!
Ryklis 10 years ago
Awesome tutorial, thanks you !! Oh, Want a A3 paper crafted ? Here it is ! (But not mine)
http://95n.deviantart.com/art/cute-ivysaur-flower-...
Oh hey, thanks for posting the link! Glad I inspired someone! :)
Using clay to smooth the model out seems like a good idea.
claramecium 10 years ago
Bulbasaur also used to be one of my favorite Pokemon.
Cool. I used to really be into Pokemon when I was little.
RyPKelley 10 years ago
Glad you like it! Yeah, Ivysaur works much better here, because of its flatter back.
I figured more people would know Bulbasaur though :)
M3G 10 years ago
This is so COOL!
anapet01 10 years ago
Danger is my middle name 10 years ago
I love this idea, it looks great!
