Bullet Torch
Intro: Bullet Torch
Turn a magnum 44 bullet into a mini torch
I brought a bunch of used bullets from Etsy for a project that’s currently a work in progress. I had a heap left over and have been dreaming-up all types of projects to create.
Turning a 44 magnum bullet into a torch was no easy feat. There isn’t much room inside one and the wiring was tricky. The end result though looks great and the torch works brilliantly, especially as it is only one, super bright LED.
I also added a small ring to the end of the bullet so you can add it to your keys or as a necklace. The switch I used was a micro one I scavenged from an old circuit board. I think an even smaller one would work great, but this is all I had at the time.
So here’s how it’s done…
STEP 1: Things to Gather
Parts:
1. 44. Magnum bullet casing. These can be purchased from Etsy
2. Super bright LED – eBay
3. Micro switch – eBay
4. Button batteries CR927– eBay
5. Lock Nut – it needs to be just larger than the opening of the bullet. I used a lock nut.
6. Small springs. These were scavenged from a small LED candle I had. Most small toys have springs in them in the battery compartment
7. Thin piece of copper
8. Thin wire
9. Heat-shrink
Tools:
1. Drill
2. Grinder
3. Pliers
4. Sandpaper. 240 grit and 800 to 1200 grit paper
5. Super glue
6. Soldering iron
7. Vice
STEP 2: Making the Bullet Head
The first step is to make the bullet head. You need to find a lock nut that is slightlybigger than the bullet.
Steps:
1. Grind all of the corners off on the nut using a grinder. Go slowly and hold the nut with some needle nose pliers so you don’t lose the shin on your fingers.
2. Once the corners have been removed, continue to round out the nut on the grinder. Make sure though that you don’t grind too much as the nut will be too loose for the bullet.
3. Once you have the nut rounded and is slightly larger than the bullet, you can then start to sand down the nut.
4. Use heavier sandpaper first like 240 grit or 400, and then move onto a 800 or 1200 grit for the final smoothing. On the lock nut there is a lip at the top, I tried not to sand this as it gives the nut a more “bullet” look. It takes a little longer to sand but the effect is worth it.
STEP 3: Adding the Ring
Steps:
1. Twist a piece of copper around some needle nose pliers and make a ring out of it.
2. Cut the copper and bend into shape so it makes a circle
3. Next add some flux and solder to the end of the bullet, heat-up with a small blow torch and carefully attach the ring so the solder melts into it and the bullet.
STEP 4: Adding the Battery Spring and Switch
This is probably the fiddliest part. You need to add the switch to the bullet caseand solder one of the legs to the inside!
Steps:
Spring
1. Find a spring to use. The best ones are ones used in battery cases like AAA battery case or something even smaller.
2. The springs are usually mounted onto a piece of metal. Cut this down so it fits into the bullet case
3. Stretch the spring so it comes just past half way up the bullet case. If you don’t do this then the batteries will be too loose in the case
Switch
1. Drill 2 small holes into the bullet case as shown below. One needs to be slightly larger so the wire on the switch can fit through.
2. Solder a piece of thin wire to one of the legs of the switch and add a piece of heat shrink to it. Thread the wire through the larger hole in the bullet and push the legs of the switch through both holes.
3. Bend the leg of the switch without wire so it is touching the inside of the bullet case.
4. Solder the leg onto the bullet case.
STEP 5: Adding the LED and Head of the Bullet
Steps:
1. Add the Led to the inside of the nut and super glue into place
2. Next trim one of the LED legs and solder on the wire from the switch. Make sure you add a small piece of heat-shrink to cover up the exposed wire. Bend the leg down and across to make way for the spring.
3. Trim and solder a small spring to the other led leg.
Note – when doing this section, make sure you are aware of the polarities of the LED. On my one I had the positive end of the battery facing-up which did work but wasn’t ideal. You really want the positive facing down. The reason being the solder on the switch will probably touch the side of the battery and on button batteries, the side is positive as well as the bottom of the battery.
4. Add the batteries to the bullet case. The batteries I used are actually 3v but very low amperage so the total is 6v. Usually this would just blow the LED straight away, but the low amperage ensures this doesn’t happen (I think anyhow!)
5. Carefully push down the top of the bullet into the case. If you find that the bullet head is a little loose, you can always slightly bend the top of the bullet case in a couple of spots. Just be careful not to bend too much!
6. Test! You should now have a super small, super bright bullet torch.
STEP 6:
This was a really fun and challenging project. When I discovered that I had some button batteriesthat would actually fit into the bullet case, I knew I had to try and make a mini torch.
I was especially happy on how the head of the bullet turned out. For some time I was hunting around in my shed, trying to find the best bit to add for the head. As soon as I saw the bolts I knew what to use. Smoothing them out worked really well, although it took a few goes before I perfected it. The hardest thing about making the bullet head was ensuring that it wasn’t too small to fit correctly into the bullet. The trick is to make sure that it just doesn’t fit before you start to sand.
One of the trickiest parts was the switch! I should have wired-up the batteries so the negative pole was at the top and the positive at the bottom. Since I didn’t, the soldering point on the switch to the bullet kept touching the side of the battery and wouldn’t work. I fixed it in the end but it is very frustrating trying to work out what was wrong. If you could incorporate the micro switch inside the bullet and only have the top of the switch sticking out of a hole, then this would have kept the bullet shape more true. It would be finicky but I think you could do it…Maybe next time.
31 Comments
FNX1992 3 years ago
monster_mash 8 years ago
gravityisweak 9 years ago
the.texas.trucker 9 years ago
Why? Spent ammunition is not live ammunition.
The answer to that is mainly because Massachusetts and DC specifically define spent shell casings as ammo. If you look into it a little bit you can find many horror stories. It sounds unbelievable, but its true.
lbrewer42 9 years ago
WHAT? I had no idea anyone in the States had to be licensed to own ammo! This is shocking, disturbing, and unconstitutional all at the same time...
Anyway - since this is not ammo - it is just the case - does this (criminal abuse of power) law also hold? Would someone actually be arrested for having a bullet casing as a flashlight?
I know I have a spent "bullet" mounted on my belt buckle and have visited DC many times. I have also wornb it while in Massachusetts. It horrifies me to think there is actually someplace in the US where they would try to arrest me for this. I have to look into this ... and keep wearing the buckle when I am there :)
Honest... I tried to write that first sentence of that last paragraph without the parenthteical statement - but spent patriot blood cries out too loudly in the deepest levels of my American heart.
I've looked into this very thing before, and its quite disturbing. Maybe we could talk more about this at length if we started a discussion on it in the appropriate section.
Yes, if you go strictly by the law, even a spent shell casing is illegal. I think what is boils down to is if the officer wants to or not. But look it up, its pretty well documented. The only places I could find records for were Washington D.C. and Massachusetts though.
Here is a pretty definitive link, at least to MA but it even tells you the exact law.
http://www.massbar.org/publications/lawyers-journal/2011/july/don%E2%80%99t-pick-up-after-others,-or,-the-danger-of-spent-shell-casings
lonesoulsurfer 9 years ago
I'm actually surprised that I could import them in Australia. I guess a spent cartridge doesn't pose too much of a security risk.
AJ_Smoothie 9 years ago
Really liked this project! Thanks!
Anytime - thanks for checking it out!
zack_man888 9 years ago
*Sigh* When will people realize those are called cartridges and not bullets?Granted, it does have part of a bullet in it. ;) All joking aside, this is a very creative idea, and definitely something that goes near the top of my electronics gadgets "to do" list. Thanks for sharing!
Kris Jacobs 9 years ago
If you want to get technical - LoneSoulSurfer is NOT using a cartridge.
This Instructable is using a case, or shell.
A cartridge consists of: Case, Primer, Propellant, Projectile.
A bullet is a projectile stuck in the end of a case, when combined with primer & propellant make a cartridge.
Sorry I misread the instructable. He did say they were used shell casings, which would not qualify as a cartridge. Thanks for your input Kris Jacobs.
crispernakisan 9 years ago
Swanky!
artworker 9 years ago
Can this be taken passed the airport security? Nice ible though!
haha yeah good question! actually I'm flying tomorrow - tempted to try. knowing how tight the laws are now I doubt I'd get past the first gate.
I have flown in quite a few countries with my belt buckle that has a bullet mounted on it (casing I got my first buck with). The ONLY place I had trouble was in Athens, Greece. One of the X-ray attendants told me he could not allow it and confiscated it; while another attendant behind him (gave me an OK sign, and winked at me). After getting through the x-ray place, the other attendant met me before I got on the plane and handed it back to me :^).
I have never had a problem in US cities. It is obvious it is not capable of any harm.
you could definitely do it. Initially I was going to do just that but I wanted to add a loop to hang it on.
