Burl Slab Night Stand
Intro: Burl Slab Night Stand
My guest room needed a bed side table and lamp so guests wouldn't need to get out of bed to turn off the light and have a convenient place to put a glass of water and charge their phone etc.
STEP 1: Sourcing Parts
I went around the estate looking for things I could use to build said table and light stand.
what I found was an old burl slab I had purchased a few years ago while out yard selling, a nice old wall mount lamp fixture and a switch in my box of electrical supplies, a scrap of MDO plywood leftover from sign I painted.
STEP 2: Fitting the Table
the first thing I did was to cut a slot with my circular saw. the slot turned out to be a tight fit so I left it alone, I had planned on screwing and gluing but no need as the fit was tight enough that I needed to hammer it in place.
if things should change in the future I can of course do the gluing and screwing at a later date.
STEP 3: Mounting the Light Fixture
the next step was to locate and set the light fixture. I drilled a hole through the slab then used my 4" angle grinder with a 36 grit flap wheel to level out the burl surface enough to create a somewhat flat area.
STEP 4: Running Wires
I flipped the slab over and using my angle grinder again cut some grooves to run wires and the switch.
for the switch I started with the drill and bore out some of the wood to make a pocket big enough for the switch, then used a die grinder with steel burs to carve out the pocket to a suitable depth and capacity for the switch.
I mounted the switch just under the table area so that it is hidden from view for the most part
STEP 5: Wiring
I used wire nuts to wire everything together and then had to carve out spaces for the wire nuts in the back of the slab.
after wiring I used aluminum tape to hold everything in place, I could have easily used plumbers tape and screws to do the job but would have needed to relieve the areas as the slab is flush mounted to the wall.
STEP 6: Finished and Mounted
while I just screwed it to the wall into a stud, I could have also made up a french cleat and used that as well.
I did use a scrap of 3/4 by 3/4 wood as a shelf to hold the weight at the bottom of the slab out of sight.
4 Comments
Thejesterqueen 7 years ago
peterman921 7 years ago
thanks
kylegilbert 7 years ago
thanks, just an off the cuff project
