Buttons From Avocado Pits
Intro: Buttons From Avocado Pits
I’ve been inspired by avocado pit carvings for a while. However, because of how much the pit can warp while drying, I didn’t really get into it. So I had the idea of making little buttons. This project is quite simple, and the result is beautiful and can be used in other projects. I had a lot of fun doing it.
STEP 1: Preparing the Pits
Leave the avocado pit in a dry place for a day or to until the skin becomes dry and crackly. Peal the skin off and split the pit into two halves.
STEP 2: Start Cutting
The peeled pit surface is shiny, but the inside is matte. Using a knife cut off thin layers from the surface of the pit until no shiny areas are left. This helps prevent wrinkling and warping when drying. Cut the bottom so it's flat.
STEP 3: Shaping
Push a round cookie cutter into the flesh of the pit. Remove the cutting from the cookie cutter and slice it into 5 mm thick sections. Repeat this until you run out of avocado pit. Using the knife round off the edges by cutting off small sections at a time until you get a smooth shape.
STEP 4: Drying and Sanding
Dry the buttons under a weight. Sand the surface so it’s smooth. Mark out the buttonholes with a pencil.
STEP 5: Drilling
Drill the buttonholes using a hand drill. To hold them in place while I drilled, I used double sided tape to hold it on a wooden block.
STEP 6: Finishing
To make the colours more vibrant and make the buttons more water resistant I used a mixture of beeswax and coconut oil. I rubbed it in using a piece of cloth. However, any wax meant for wood finishing that you have on hand will work well. That’s just what I had.
STEP 7: Experimenting With Shapes: Squares
I tried the same process with a square cookie cutter. I found it difficult to remove thick chunks of avocado pit from the cutter so my recommendation when using cutter shapes with corners is to first slice the pit halve into 5 mm thick sections and only then use the cookie cutter on them. With squares I also drilled 4 holes instead of 2.
STEP 8: Experimenting With Shapes: Triangles
I used the same process for triangle buttons. It worked well. The shape isn’t very practical, but they make really cute decorative buttons.
22 Comments
lindbergh27 8 months ago
Does't putting a weight on top prevent water from evaporating?
indivisibl 8 months ago
tah5561 8 months ago
WUVIE 8 months ago
wannabemadsci 8 months ago
ImprovCrafting 8 months ago
I realize you might not want to risk destructive testing.
SparkBark 8 months ago
bluebird129 8 months ago
Knitknut 8 months ago
cspann560 8 months ago
