C# Serial Port Communication Arduino
Intro: C# Serial Port Communication Arduino
These days, I'm learning serial port communication and want to write a simple demo on my LattePanda. LattePanda is a Win10 single board computer, it integrated Arduino Compatible Processor, so I can run this demo just on one LattePanda board! This post is mainly about serial communication from the Arduino to the PC and communicate from PC to Arduino in C#.
If you don't have a LattePanda, you can connect the Arduino to your PC instead! Hope this tutorial useful for you.
Feel free to ask me if you have any problems while running this demo!
STEP 1: What You Need:
- Arduino Leonardo
- PC
STEP 2: 1.Communicate From the Arduino to the LattePanda CPU
- Arduino:Send '1'
- Computer: Receive '1'
(You can try to send the data of your sensor or any other parameter if you want.)
Creat a new Console application. Use Console to recieve the data.
I found an easiest way to do this.
C# code:
using System;
using System.IO.Ports;
using System.Threading; namespace ConsoleApp1 { class Program { static SerialPort _serialPort; public static void Main() { _serialPort = new SerialPort(); _serialPort.PortName = "COM4";//Set your board COM _serialPort.BaudRate = 9600; _serialPort.Open(); while (true) { string a = _serialPort.ReadExisting(); Console.WriteLine(a); Thread.Sleep(200); } } } }
Arduino sketch:
void setup() {
Serial.begin(9600);
}void loop() { Serial.print('1'); delay(200); }
Press Start, and you will see the result like the picture above. We received the data from Arduino successfully.
Success? If you have any questions, feel free to ask me!
STEP 3: 2. Communicate From the LattePanda CPU to the Arduino
- Computer: Send '1' or '0'
- Arduino: Receive '1' and turn on the light. Receive '0' and turn off the light.
Creat a new Windows Form Application and make two buttons. See the picture above.
C# Code:(Winforms)
using System;
using System.Windows.Forms;
using System.IO.Ports; namespace lightcontrol { public partial class Form1 : Form { SerialPort port; public Form1() { InitializeComponent(); this.FormClosed += new FormClosedEventHandler(Form1_FormClosed); if (port==null) { port = new SerialPort("COM7", 9600);//Set your board COM port.Open(); } } void Form1_FormClosed(object sender,FormClosedEventArgs e) { if(port !=null &&port.IsOpen) { port.Close(); } } private void button1_Click(object sender, EventArgs e) { PortWrite("1"); }private void button2_Click(object sender, EventArgs e) { PortWrite("0"); } private void PortWrite(string message) { port.Write(message); } } }
Arduino sketch:
const int LedPin = 13;
int ledState = 0;
void setup() { pinMode(LedPin, OUTPUT); Serial.begin(9600); } void loop() { char receiveVal; if(Serial.available() > 0) { receiveVal = Serial.read(); if(receiveVal == '1') ledState = 1; else ledState = 0; } digitalWrite(LedPin, ledState); delay(50); }
If you click the button 'ON', you will see the light(pin13) turns on.
So far so good? Feel free to post your qusetions, I will try my best to help you!
There's another way to do this, you can see the tutorial here.
STEP 4: Summary
These are the simplest way to communicate between arduino and your PC.
Most of the projects need Arduino to send data to computer and use computer to analize data or do other thing. So communicate is necessary and very important. Hope it's helpful for you. If you have any questions please let me know.
14 Comments
Emil Albert 4 years ago
_serialPort.DtrEnable=true;
_serialPort.RtsEnable=true;
I just spent nearly a day finding this solution ...
kingofninjas 1 year ago
ClaudioCas 3 years ago
I had the same issue too with .net Core 3.1 and System.IO.Ports 5.0.1
My program could only read a few lines and then crashed.
With this 2 lines everything works great.
Thanks, I also spent a couple of hours...
aroslavv 4 years ago
KilerKazanu 1 year ago
mjzrpr 2 years ago
ErnestJoubert 4 years ago
I suggest to have a look at Sharer, it is a modern .NET library to read/write vatriables and remote call function on Arduino.
https://github.com/Rufus31415/Sharer
var connection = new SharerConnection("COM5", 115200);
connection.Connect();
connection.WriteVariable("myVar", 12);
SonL23 4 years ago
I have a question , if i connect pc to arduino with rs485 is that work?
AnthonyC94 5 years ago
Serial IN C#
private void serialPort1_DataReceived(object sender, SerialDataReceivedEventArgs e)
dataIN = serialPort1.ReadExisting();
this.Invoke(new EventHandler(ShowData));
private void ShowData(object sender, EventArgs e)
int dataINLength = dataIN.Length;
lblDataInLength.Text = string.Format("{0:00}", dataINLength);
if (chBoxAlwaysUpdate.Checked)
uPCTextBox.Text = "";
uPCTextBox.Text = dataIN;
var text = uPCTextBox.Text;
Clipboard.SetText(text);
lblDataIn.Text = Clipboard.GetText();
uPCTextBox.Text = lblDataIn.Text;
else if (chBoxAdd2Data.Checked)
uPCTextBox.Text += dataIN;
Arduino Code:
int nbts = 3;
int startpin = 10;
int bts[3];
boolean btgs[3];
int incomingByte = 0;
//End Button Declarations
void setup() {
Serial.begin(9600);
for(int i=0;i<nbts; i++) bts[i] = i+startpin;
for(int i=0;i<nbts; i++) btgs[i] = false;
for(int i=0;i<nbts; i++) pinMode(bts[i], INPUT_PULLUP);
delay(500);
Serial.println("Ready for Input when you are!");
void loop() {
readBtn();
void readBtn(){
for(int i=0;i<nbts;i++){
if(digitalRead(bts[i])==LOW){
if(!btgs[i]){
btgs[i] = true;
if(bts[i]== 12){
Serial.println("");
delay(250);
else if(bts[i]== 11){
btgs[i] = false;
Serial.println("629874846497");
delay(250);
else if(bts[i]== 10){
Serial.println("1234567891234");
btgs[i] = false;
delay(250);
Data Search Code:
private void btnSearchUPC_Click(object sender, EventArgs e)
try
this.inventoryTableAdapter.SearchUPC2(this.inventoryDataSet1.Inventory, uPCTextBox.Text);
catch (System.Exception ex)
System.Windows.Forms.MessageBox.Show(ex.Message);
C# Search Code:
this.Adapter.SelectCommand = this.CommandCollection[4];
if ((UPC == null)) {
this.Adapter.SelectCommand.Parameters[0].Value = global::System.DBNull.Value;
else {
this.Adapter.SelectCommand.Parameters[0].Value = ((string)(UPC));
if ((this.ClearBeforeFill == true)) {
dataTable.Clear();
int returnValue = this.Adapter.Fill(dataTable);
return returnValue;
And SQL Search Query Code:
SELECT ID, UPC, ITEM, MODEL, BRAND, DESCRIPTION, VENDOR, VENDOR_CONTACT, VENDOR_PHONE, VENDOR_ADDRESS, VENDOR_EMAIL, DATE_ORDERED,
DATE_RECEIVED, QUANTITY, COMMENTS, ADMIN
FROM Inventory
WHERE (UPC LIKE @UPC + N'%') //Search String
AndersM10 5 years ago
Great tutorial but this only works if you know the serial port and the application will crash the arduino is not connected.
How would you scan all the open serial ports, send out pings for the arduno, listen for a response and show connected/not connected? Would be great if you did this tutorial.
hackmattr 5 years ago
So the user selects the COM port for the arduino and then clicks on connect to connect to that COM port. The third photo shows my connect function.
Now it won't select the COM port for the arduino automatically unless its the first in the list, but it is an option to prevent problems of connecting to a nonexistent port when the arduino is unplugged..
375668457 5 years ago
I get it! I will do it these days!
rgxOhm 5 years ago
Nice Tutorial. For me (noob and learning) would be nice the Arduino Schematic; but no big deal. There are tons of schematics to follow up.
The part I Loved Most was in fact the way you Code SerialPort (Programmatically). I've been struggling to make it work. Thankful for that. (New Skill Achieved here!)
Either way: I know my question has nothing to do with this; but since I'm having difficulties in finding a "noob tutorial for me"; perhaps you could help me out.
In my project the intention was to read and write to Arduino.
i.e: Read Specific Pins Data and Turn them Pin ON/OFF
Is it possible to send Text from C# App and Receive it in Arduino?
// See Pseudo Code Image Attached
Keep up the good job.
Thanks in advance.
Great tutorial, this was very useful, defensively going to use this allot.
