CARD BOX COMPUTER CASE
Intro: CARD BOX COMPUTER CASE
You might think... this guy doesn't have anything else to do... but the thing is... I moved from Portugal to the United Kingdom and the IBM Case was too heavy, so i had to choose, the case or some clothe :D...
But to do this you have to check if everything fits, and if you have cable lenght.
STEP 1:
First, put the board on the side of the case and with a nail puncture the holes of the board.
STEP 2: The Power Supply
Just cut the hole power supply
STEP 3: Vent
Opening the vent hole and build the vent tunnel.
STEP 4: Hard Drives
Let's what we can do so... they don't overheat and burn .
STEP 5: Final Wiring
So this can work, i need the on/off button and some usb ports and some sound!
STEP 6: Opening the Holes in the Back
Final cuts, for all the other ports .
STEP 7: Will It Work?
Well, now i was nervous ... will it work ? will it burn immediately? let's check!!
16 Comments
abun1991 13 years ago
netbus 13 years ago
junits15 13 years ago
abun1991 14 years ago
bowmaster 14 years ago
yeerk21 14 years ago
nupi 14 years ago
The CPU, working with AE and Premiere and Photoshop, never exceeded the 70º.
The smaller HDD( with the OS ) had a maximum of 55º,
The 1TB HDD reached the 70º on a peek.
Temperatures are ok, but i'm still going to install a small fan over the HDD, so i can unistall the temperature software, because i really need all CPU and memory available.
Bartboy 14 years ago
nupi 14 years ago
I look forward to see your knex computer ;) good luck with that!
bensie 14 years ago
nupi 14 years ago
Thank you!! :D i´m glad you liked it !
MrGreggan 14 years ago
nupi 14 years ago
ziptang 14 years ago
Case or clothes, I think you left more behind than just the case
nupi 14 years ago
And if you use your reading glasses, you can see that the hard drives have about 1 cm between them.
I can also inform you my dear brainiac, that this IBM motherboard has 4 temperature sensors and the hd also have one each.
God created man, and man created the software to monitor temperature. temperature is limited to 75Cº.
