CONSTRUCT a HARP IN 6 EASY STEPS WITH PICTURE IN HOUSEHOLD THINGS
28,263
20
4
Introduction: CONSTRUCT a HARP IN 6 EASY STEPS WITH PICTURE IN HOUSEHOLD THINGS
About: " A sp€cial fAc€, A spec¡A! $M¡L£, A special sOmE1, A $pEC¡A| HUg from M€ t¤ ú. A $p€c¡@| persOn if ù føùnd in U.
YOU CAN MAKE AN HARP WITH VERY STEPS
Step 1: A Wooden Chunk
Take a piece of wood and carve a shape of harp from it .To carve the shape of the harp give it to shop where "JIGSHOW " machine is used he/she will take money as per your size.
Step 2: Shape of the Harp
Now take a knife and give the final touch to the harp,it means that with help of the knife smooth the inner surface and outer surface so that you will be not cut by the very thin piece of wood which come out after the cutting.
Step 3: COLOURING
Now it's time for colouring take some colour and do which colour you want to do but don't apply any of the light colour only and only apply a dark colour so that your harp's original wooden colour will not show.Apply the colous both the sides and in inner and outer border.
Step 4: HOLES
Now make the holes in the harp at distance of 1cm with the help of the drill so that when we will tie the string it will not mash.But remember that how much you have done holes in a side just count and that only hole in the upper side.
Step 5: TIE STRINGS
Now take a very strong string,Now pass the string from the first hole and make a tie there,then from the end of the string pass it from the opposite side first hole then pass it from the second hole of the same side,now do like this and at the end of the holes means at last hole make a another tie.
Step 6: TIME FOR FINAL TOUCH
Now it's time for final touch take white color and apply n the hole so that some unpainted portion will be painted apply the same pattern on the both sides
NOW YOUR HARP IS READY .
from,
meet.
thank you.
Be the First to Share
    • Puzzles Challenge
      Puzzles Challenge
    • CNC and 3D Printing Contest
    • Lamps Challenge
      Lamps Challenge
    4 Comments
    swilliams-2
    swilliams-2
    Question 4 years ago on Step 5
    Yes my question what are the strings made out of???
    MulinZ
    MulinZ
    what's the material for strings? metal wire?
    d.fang3
    d.fang3
    4 years ago
    this is good
    Fun and quick build! You'll have to update us if you learn how to play any songs on it! You should think about entering our First Time Authors Challenge.
