CPX Headlamp
Intro: CPX Headlamp
This is a circus playground express headlamp. This headlamp consists of a go pro head strap, a CPX, a battery, and a servo to make it work. This was created specifically for people who are outdoors a lot such as hikers and construction workers but it can be used by anyone. The headlamp also has a lid that is meant to cover the light when it is bright and it is meant to go up when it is dark.
STEP 1: Download
Click on link attached to download CPX holder and battery holder. Press export, .STL (see in picture attached)
STEP 2: 3D Print
- Once you have it downloaded go to http://cloudprint.makerbot.com
- Select "start new print"
- Switch the "Method X" on the top of the screen to "sketch"
- Then click import and attach your downloaded file
- In the Makerbot quick setting change your support type to "breakaway" and your base layer to "none"
- Click export then save it to a USB and print it when you are ready
STEP 3: Download and Print
Download Servo holder to your computer and 3D print it the same way you 3D printed in the previous step using this link
STEP 4: Glue
Attach the servo holder to your CPX holder using gorilla glue and a clamp
STEP 5: Attach 3D Print
Insert the CPX into the CPX holder using screws and attach it to your GoPro head-strap
STEP 6: Servo Attachment and Set Up
- Take servo and attach the part with 1 wing
- Then take your alligator clip wires and attach the BROWN to GND, the RED to VOUT, and the YELLOW OR ORANGE to A1 on your CPX
STEP 7: Cardboard Cover
Cut out a cardboard circle about 2 inches in diameter
STEP 8: Attach
Attach Cardboard cover to the headlamp using a paperclip and glue
STEP 9: Code
- Download and Install Mu editor https://codewith.mu/
- Copy and paste code into Mu Editor
- Save to code.py
- This code shows that when light it detected the lid will go down and when it is dark the lid will go up and the light will flash
