How to Calculate Pi š¹ Values? Calculating Pi š¹ Values Using Polygon Trigonometry | Science Experiment | Mathematics
Intro: How to Calculate Pi š¹ Values? Calculating Pi š¹ Values Using Polygon Trigonometry | Science Experiment | Mathematics
As we all know that theĀ circleĀ is just aĀ polygon, withĀ infiniteĀ sides. So, with this concept, we canĀ calculateĀ the value ofĀ pi š¹. With simple trigonometry. We will consider every object as aĀ circleĀ &Ā polygonĀ at theĀ same time. And use theĀ naming convention interchangeablyĀ so, don't get confused.
STEP 1: Circle Is a Polygon With Infinite Sides
We can see in the above figure. As we go onĀ increasingĀ the number ofĀ sidesĀ of the polygon its shape starts to look like aĀ circle.
When the number ofĀ sidesĀ of theĀ polygonĀ is equal toĀ infinityĀ it becomes aĀ perfect circle.
STEP 2: Pi š¹ Vs. Sides
In the graph shown above. It is a graph of theĀ š¹ piĀ values calculatedĀ versusĀ the number ofĀ sidesĀ of the polygon used to calculate that value. TheĀ moreĀ the number ofĀ sidesĀ the more accurate the value we getĀ approximatedĀ toĀ 3.141592653589793238.
STEP 3: Polygons With Diagonals
The above figure shows the diagonals of the polygon.
TheĀ number of sides of polygonĀ =Ā number of diagonals.
For aĀ perfect circle, there will beĀ infinite diagonals. And theĀ lengthĀ of the diagonal will beĀ equalĀ to theĀ diameterĀ of the circle.
So, we will consider theĀ radiusĀ =Ā digonal/2.
STEP 4: Decagon for Calculations
Let us consider thisĀ decagonĀ for the explanation and calculation of the š¹ (pi) value.
It hasĀ 10 sidesĀ &Ā 10 diagonals.
STEP 5: Angles (Īø) of Polygon
Let us consider theĀ angleĀ between any two diagonals of the polygon asĀ theta(Īø).
ThetaĀ =Ā 360Ā /Ā no of sides
for decagon :
Īø = 360/ 10
Īø = 36Ā°
STEP 6: Consider This Triangle
Let us consider thisĀ triangleĀ for the calculation.
STEP 7: Triangles in Polygon
Every polygon has diagonals. So aĀ triangleĀ is formed betweenĀ two diagonalsĀ and theĀ side.
So, we can use thisĀ triangle-based methodĀ for any polygon toĀ calculateĀ the value ofĀ pi.
STEP 8: Triangle for Calculations
This is theĀ triangleĀ to be used forĀ calculation. We haveĀ separatedĀ it out from polygon. ForĀ better visualizationĀ andĀ easier calculations.
STEP 9: Specs of Triangle
There is anĀ angleĀ Īø thetaĀ between two diagonals. TheĀ two sidesĀ of the triangle can be consideredĀ radiiĀ because it is equal to theĀ diagonal/2Ā of the polygon. The other side of the triangle is equal to theĀ edgeĀ of theĀ polygon.
STEP 10: Calculating Theta Ī
The values we know are theta, radius, and phi.
To find: base,side
let us considerĀ raduisĀ =Ā 10
ĪøĀ =Ā 360 / no of sides
for decagon :
Īø = 360 / 10
Īø = 36Ā°
STEP 11: Calculating Phi Ī¦
As per the figure shown. The phi value is equal to half of the theta value.
Ī¦ = Īø /2
for decagon:
Ī¦ = 36 /2
Ī¦ = 18Ā°
STEP 12: Calculating Base of Triangle
This is aĀ right-angled triangle.
ThereforeĀ baseĀ =Ā radius x sin(Ī¦)
for decagon:
base = 10 x sin(18)
base = 3.09016994
STEP 13: Calculating Edge of Polygon
The side length of the polygon is equal to twice the base of the right-angled triangle.
side length = 2 x base
for decagon:
side length = 3.09016994 x 2
side length = 6.18033988
STEP 14: Calculating Perimeter of Polygon
The circle is a polygon with infinite edges.
TheĀ perimeter of any polygonĀ =Ā no of sides x length of the side
for decagon:
perimeter = 10 x 6.18033988
perimeter = 61.8033988
STEP 15: Calculating š¹ Pi Value
We are considering a circle as a polygon with infinite sides.
So, the perimeter of the polygon is equal to the circumference of the circle.
circumference of circle = 2 x š¹ x radius
2 x š¹ x radius = no of sided x length of side
š¹ = (no of side x length of side)/(2 x radius)
That's how we calculated the value of š¹.
for decagon:
š¹ = (10 x length of side)/(2 x 10)
š¹ = (10 x 6.18033988)/(2 x 10)
š¹ = 3.09016994
STEP 16: Increasing Sides Reduces Error
In the graph shown above. It is a graph of theĀ š¹ pi values calculated versus the number of sides of the polygonĀ used to calculate that value. TheĀ moreĀ theĀ number of sidesĀ the moreĀ accurateĀ the value we get approximated toĀ 3.14159.
TheĀ tableĀ has the values of theĀ number of sidesĀ of theĀ polygonĀ and the respectiveĀ pi value calculatedĀ from that figure.
STEP 17: Conclusion
We haveĀ successfully calculatedĀ theĀ š¹ valueĀ with the help ofĀ trigonometryĀ andĀ polygons.
