Camping Tripod for Cooking Over Fire
Intro: Camping Tripod for Cooking Over Fire
This is a step by step guide to making a sturdy tripod you can use to hang a cook pot, dutch oven, coffee pot, or anything else you want to hold over a campfire.
There are very nice commercially produced tripods available, including expensive wrought-iron ones. This one can be made for $20-$25 if you buy everything brand new, and will be nearly as durable, and certainly lighter. It could be made cheaper, even free if you can scavenge the parts from scrap. (Update - I just saw a wrought-iron one at Joe's sporting goods for $45. I think I'll stick with my conduit one.)
Credit for this concept goes to Junior Doughty of www.deltablues.net. His tripod can be found at: http://www.deltablues.net/tripod.html
STEP 1: Materials and Tools
You will need:
3 sections of 1/2" conduit 4' long or longer
3 sturdy eye bolts
2 S-hooks
4' of chain - the kind with the wire links is great.
Tools:
Hammer
Tubing cutter or hacksaw
Pliers
Wire cutter
3 sturdy eye bolts
2 S-hooks
Tools:
Hammer
Pliers
Wire cutter
STEP 2: Cut the Legs
First, cut the conduit to the desired length. I made mine 4'8", but you can make them any length you like.
The tubing cutter has little rollers and a cutting wheel on a clamp. Tighten the clamp onto the conduit where you want the cut then tighten it down, turn, and repeat until the conduit is cut all the way through.
A hacksaw may also be used to do the job.
If you don't have a way to cut the conduit, the hardware store may cut it for you when you buy it.
STEP 3: Open One Eye Bolt
Open one eye of one eye bolt using pliers, or lever it open with pliers and a scrap of tubing. This is the hardest part if you bought beefy eye bolts like these. It was probably overkill.
STEP 4: Assemble the Eye Bolts and Chain
Now put the other two eyes and one end of the chain onto the open eye bolt. Use the hammer to reclose the open eye securely so it all stays together.
STEP 5: Connect the Legs
Put the shafts of the eye bolts into the ends of the legs and stand it up with the legs equidistant, like it will look over a campfire. Put one of the S-hooks on the chain near the top and use the pliers to close it tight. This will be the adjuster for the cookpot height.
STEP 6: Cut the Chain to Length
Cut the chain to the desired length, using your cookware to measure the longest possible chain length desired.
It is long enough if the pot can sit on the ground and remain on the chain.
Put another S-hook onto the end of the chain and close with pliers.
STEP 7: Hang Cookware
Hang your dutch oven, coffee pot, or whatever on the chain and make sure it will support its weight. Ensure the adjuster hook will get the cookware to the level you want.
STEP 8: Fold It Up
The beauty of this design is that it can collapse easily for storage and transport.
STEP 9: Customize and Enjoy
You can add lost of different useful features to this basic design. Add an extra hook to hang utensils, paint it with stove paint, make a mechanism to permanently connect the legs to the head, whatever you want.
Later on I am going to drill holes in two legs and add eye bolts to hold an additional piece of conduit from which I can hang more chains and hooks for more pots, or to hang boots for drying. (My brother-in-law has burned up two pairs of boots in as many hunting seasons because he puts them too close to the fire.)
The lower ends of the tripod should remain cool enough that you can pick up one leg at a time bare-handed to move it around a little bit. If you want to raise or lower the chain while it is hot, you might need oven mitts or a dutch oven lid lifter.
49 Comments
Papa_2014 1 year ago
would dispense with bending the eye of one bolt and just run the chain
through the three eyes and "S" hook it or run a bolt and nut it, very
adjustable that way, options. You all do know that they also sell aluminum conduit if weight is an issue otherwise standard EMT of your choice works great. Thanks for the idea.
xfirexstarzx 2 years ago
cube-convict 4 years ago
ingriddayton 9 years ago
6' 1/2 " poles and those big eyehooks.
He left the bolt on the eye hooks, screwed the bolts on the eye bolts as far as they could go, and pounded the eye hooks into the poles (not hard to do).
But opening that one third eye hook was a doozy. I recommend opening it using a vise before you pound it into the pole and then hammering it closed.
A carabinier hangs from one of the eye hooks and the chain hangs from that. In picture #3 you can see the doodad that holds the dutch oven. He did not cut the chain, the length can be adjusted by another eyehook at the end of the chain.
This is going to make for some fun backyard cooking! thank you so much for this great Instructable!
eielson 5 years ago
BLACK HOLE BBQ 8 years ago
ingriddayton 7 years ago
I know this is an old post, but did you make it?
eielson 5 years ago
sjeverett75 6 years ago
mpadgitt 6 years ago
Very nice project! I'd like to reprint this in Wood-Fired Magazine. Please contact me at editor@woodfiredmag.com
Foaly7 14 years ago
pearsonry 10 years ago
Yes, but to keep it simple you could also add in-line conduit connectors and cut the legs in the middle. Gravity would hold the connectors in place.
shallahowe 7 years ago
get some tubes that are a size up. so your legs can slide inside the bigger ones.
get a nut that fits inside the bigger tube, and pound it inside. pretty easy to do with a hammer.
poke it in an inch or two deeper (either screw in the eye bolt and hammer the top in then unscrew. or put your small pole inside and hammer the top)
the bolt should be pretty immovable. when you set it up, it won't be telescopic, but you can assembled to add length.
PVF1799 8 years ago
morales07302 9 years ago
This is a great idea!! I was thinking of using black pipe for a little more strength so I can make it a bit taller. Where I go camping the fire pits are a bit oversized. Making it taller will help me get around that. Thanks a lot!!
angeldmort 14 years ago
Simplicity is key. I'm glad you enjoyed it.
KMoffett 13 years ago
I'm so glad it helped you!
glenm 13 years ago
